Welcome on the forums. Please post in English or French.
You are not logged in. You won't be able to post until you register and log in using the top-right bar.
Hi! Iam interested how calculate periods and forms of natural vibrations and form and reserves the loss of stability in attached beam case?
What commands I need to use?
file
https://docs.google.com/open?id=0B9BlA0 … UHFFcEkzdw
DEBUT();
#Read mesh
Mesh=LIRE_MAILLAGE(FORMAT='MED',);
Mesh=DEFI_GROUP(reuse =Mesh,
MAILLAGE=Mesh,
CREA_GROUP_MA=_F(NOM='TOUT',
TOUT='OUI',),);
#Assign a beam model - POU_D_E denotes a Euler/Bernoulli
Model=AFFE_MODELE(MAILLAGE=Mesh,
AFFE=_F(TOUT='OUI',
MODELISATION='POU_D_E',),);
Material=DEFI_MATERIAU(ELAS=_F(E=66000,
NU=0.3,),);
MatField=AFFE_MATERIAU(MAILLAGE=Mesh,
AFFE=_F(TOUT='OUI',
MATER=Material,),);
A = 27400.0;
I_y = 712000000.0;
I_z = 283000000.0;
J = 6180000.0;
RY = 197;
RZ = 187;
AY = 1.46472;
AZ = 4.64168;
CARA_POU=AFFE_CARA_ELEM(MODELE=Model,
POUTRE=_F(GROUP_MA='TOUT',
SECTION='GENERALE',
CARA=('A','IY','IZ','JX','RY','RZ','AY','AZ',),
VALE=(A,I_y,I_z,J,RY,RZ,AY,AZ,),),);
#Boundary conditions
#Point 1 : Fixed
Hold=AFFE_CHAR_MECA(MODELE=Model,
DDL_IMPO=_F(GROUP_NO='fixx2',
LIAISON='ENCASTRE',),);
#Load
#Point 2 : Point load
Load=AFFE_CHAR_MECA(MODELE=Model,
FORCE_NODALE=_F(GROUP_NO='loadd',
FZ=-10000,),);
# Linear elastic solution
RESU1=MECA_STATIQUE(MODELE=Model,
CHAM_MATER=MatField,
CARA_ELEM=CARA_POU,
EXCIT=(_F(CHARGE=Hold,),
_F(CHARGE=Load,),),);
# Calculate forces etc.
RESU1=CALC_ELEM(reuse =RESU1,
RESULTAT=RESU1,
OPTION=('EFGE_ELNO_DEPL','SIPO_ELNO_DEPL','SIGM_ELNO_DEPL',),);
RESU1=CALC_NO(reuse =RESU1,
RESULTAT=RESU1,
OPTION=('REAC_NODA','EFGE_NOEU_DEPL','SIPO_NOEU_DEPL','FORC_NODA',),);
# Write to .med file
IMPR_RESU(MODELE=Model,
FORMAT='MED',
RESU=_F(MAILLAGE=Mesh,
RESULTAT=RESU1,
NOM_CHAM=('DEPL','EFGE_NOEU_DEPL','REAC_NODA','SIPO_NOEU_DEPL','FORC_NODA',),),);
#Write to .resu file
FORMAT='RESULTAT',
RESU=_F(RESULTAT=RESU1,
NOM_CHAM=('DEPL','EFGE_NOEU_DEPL','SIPO_NOEU_DEPL','REAC_NODA','SIGM_ELNO_DEPL',),
VALE_MAX='OUI',
VALE_MIN='OUI',),);
FIN();Offline
you can find that in this
http://www.caelinux.org/wiki/index.php/ … ierreaubry
Any idea, Any help?
DEBUT();
#Read mesh
MAILLAGE=Mesh,
TOUT='OUI',),);
AFFE=_F(TOUT='OUI',
NU=0.3,RHO=1200),);
AFFE=_F(TOUT='OUI',
MATER=Material,),);
A = 27400.0;
I_y = 712000000.0;
I_z = 283000000.0;
J = 6180000.0;
RY = 197;
RZ = 187;
AY = 1.46472;
AZ = 4.64168;
SECTION='GENERALE',
#Point 1 : Fixed
#Load
FZ=-10000,),);
CARA_ELEM=CARA_POU,
RESULTAT=RESU1,
RESULTAT=RESU1,
Me=CALC_MATR_ELEM(OPTION='MASS_MECA',
MODELE=Model,
CHARGE=Load,);
Ke=CALC_MATR_ELEM(OPTION='RIGI_MECA',
MODELE=Model,
CHARGE=Load,);
NU=NUME_DDL(MATR_RIGI=Ke,);
M=ASSE_MATRICE(MATR_ELEM=Me,
NUME_DDL=NU,);
K=ASSE_MATRICE(MATR_ELEM=Ke,
NUME_DDL=NU,);
MODE=MODE_ITER_SIMULT(MATR_A=K,
MATR_B=M,
CALC_FREQ=_F(OPTION='PLUS_PETITE',
NMAX_FREQ=10,),);
Resul=EXTR_MODE(FILTRE_MODE=_F(MODE=MODE,
NUME_MODE=(1,2,3,4,5,6,7,8,9,10,),),);
FORMAT='MED',
RESULTAT=Resul,
FORMAT='MED',
RESULTAT=RESU1,
FORMAT='RESULTAT',
VALE_MAX='OUI',
VALE_MIN='OUI',),);
FIN();!----------------------------------------------------------------------------------------------------!
! <EXCEPTION> <CALCULEL2_71> !
! on ne trouve pas dans les arguments de la routine CALCUL de champ а associer au parametre: PCAORIE !
! - option: MASS_MECA !
! type_element: MECA_POU_D_E !
! <EXCEPTION> <DVP_1> !
! Erreur de programmation : condition non respectйe. !
! Il y a probablement une erreur dans la programmation. !
! Veuillez contacter votre assistance technique. !
! <A> <CALCULEL3_39> !
! le modиle contient des йlйments de structure !
! il faut probablement utiliser le mot-clй CARA_ELEM. !
! Ceci est une alarme. Si vous ne comprenez pas le sens de cette !
! alarme, vous pouvez obtenir des rйsultats inattendus ! !
you forgot to use the key word CARA_ELEM in CALC_MATR_ELEM.
Richard
RichardS wrote:
Richard
Thanks, Richard!
I have
new problems
! <EXCEPTION> <ALGELINE5_49> !
! nombre de valeurs propres convergйes 0 < nombre de frйquences demandйes 10 !
! erreur ARPACK numйro : 1 !
! --> le calcul continue, !
! la prochaine fois !
! --> augmenter DIM_SOUS_ESPACE = 20 !
! --> ou NMAX_ITER_SOREN = 20 !
! --> ou PREC_SOREN = 0.000000 !
! <EXCEPTION> <ALGELINE3_78> !
! Aucune valeur propre а la prйcision requise !
! --> augmenter PREC_SOREN ou NMAX_ITER_SOREN ou augmenter DIM_SOUS_ESPACE !
! Liste des alarmes йmises lors de l'exйcution du
calcul. !
! Les alarmes que vous avez
choisies d'ignorer sont prйcйdйes de (*). !
! Nombre d'occurrences pour chacune des alarmes : !
! aucune alarme !
DEBUT();
#Read mesh
MAILLAGE=Mesh,
TOUT='OUI',),);
AFFE=_F(TOUT='OUI',
NU=0.3,RHO=1200),);
AFFE=_F(TOUT='OUI',
MATER=Material,),);
A = 27400.0;
I_y = 712000000.0;
I_z = 283000000.0;
J = 6180000.0;
RY = 197;
RZ = 187;
AY = 1.46472;
AZ = 4.64168;
SECTION='GENERALE',
#Point 1 : Fixed
#Load
FZ=-10000,),);
CARA_ELEM=CARA_POU,
RESULTAT=RESU1,
RESULTAT=RESU1,
MODELE=Model,
CARA_ELEM=CARA_POU,
CHARGE=Load,);
MODELE=Model,
CARA_ELEM=CARA_POU,
CHARGE=Load,);
NUME_DDL=NU,);
NUME_DDL=NU,);
MATR_B=M,
NMAX_FREQ=10,),);
FORMAT='MED',
RESULTAT=Resul,
FORMAT='MED',
RESULTAT=RESU1,
FORMAT='RESULTAT',
VALE_MAX='OUI',
VALE_MIN='OUI',),);
FIN();Offline
up
Just follow the advice in the error message :
Usually increasing NMAX_ITER_SOREN is enough. If not, then increase DIM_SOUS_ESPACE.
Code:
! --> augmenter PREC_SOREN ou NMAX_ITER_SOREN ou augmenter DIM_SOUS_ESPACE !Usually increasing NMAX_ITER_SOREN is enough. If not, then increase DIM_SOUS_ESPACE.
Thanks, Thomas.
MATR_B=M,
METHODE='SORENSEN',
## PREC_SOREN=0.000001,
NMAX_ITER_SOREN=80,
NMAX_FREQ=10,
DIM_SOUS_ESPACE=80,
## COEF_DIM_ESPACE=8,
I have new problems.
! <EXCEPTION> <ALGELINE5_23> !
! pour le concept MODE !
! dans l'intervalle ( -0.010025 , 0.010025 ) !
! il y a thйoriquement 176 frequence(s) !
! et on en a calculй 10 !
! <EXCEPTION> <ALGELINE2_74> !
! erreur de vйrification !
If I increase NMAX_FREQ=176,
I have many problems
!----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 98 ! ! ! ! de frequence 0.002285 ! ! ! ! a une norme d'erreur de 0.000001 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 108 ! ! ! ! de frequence 0.002793 ! ! ! ! a une norme d'erreur de 0.000003 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 109 ! ! ! ! de frequence 0.002797 ! ! ! ! a une norme d'erreur de 0.000002 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 110 ! ! ! ! de frequence 0.002797 ! ! ! ! a une norme d'erreur de 0.000003 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 111 ! ! ! ! de frequence 0.002800 ! ! ! ! a une norme d'erreur de 0.000003 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 115 ! ! ! ! de frequence 0.003259 ! ! ! ! a une norme d'erreur de 0.000002 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 116 ! ! ! ! de frequence 0.003260 ! ! ! ! a une norme d'erreur de 0.000004 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 117 ! ! ! ! de frequence 0.003262 ! ! ! ! a une norme d'erreur de 0.000001 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 118 ! ! ! ! de frequence 0.003262 ! ! ! ! a une norme d'erreur de 0.000007 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 121 ! ! ! ! de frequence 0.003556 ! ! ! ! a une norme d'erreur de 0.000011 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------! !----------------------------------------------------------------------------------! ! <EXCEPTION> <ALGELINE5_15> ! ! ! ! pour le concept MODE le mode numйro 122 ! ! ! ! de frequence 0.003556 ! ! ! ! a une norme d'erreur de 0.000008 supйrieure au seuil admis 0.000001 ! ! ! ! Conseil: Si vous utiliser la mйthode 'TRI_DIAG' ou ! ! 'SORENSEN' vous ! ! pouvez amйliorer cette norme en: ! ! - augmentant la valeur de COEF_DIM_ESPACE (par dйfaut valeur 4 pour TRI_DIAG ! ! ! ! et 2 pour SORENSEN), ! ! - rйduire le nombre de valeurs propres recherchйes (NMAX_FREQ ou taille de ! ! la BANDE). ! !----------------------------------------------------------------------------------!
up
tomaiilyk,
"...a une norme d'erreur de 0.000001 supйrieure au seuil admis 0.000001"
means that the eigenvalue is less precise than requested (Default is SEUIL=1E-06). You can lower this precision:
MODE_ITER_SIMULT(.....
VERI_MODE=_F( . .
STURM='OUI',
SEUIL=1E-04),
Also, the error should not occur, if You renounce on the Sturm, STURM='NON',
Regards Johannes Ackva
______________________________________________________________________
Ingenieurbüro für Mechanik
Dr.-Ing. Johannes Ackva
Markgrafenstr. 21
D 91717 Wassertrüdingen
next CODE-ASTER-courses
*** Code-Aster QuickStart, 8-9 of May 2012, at Gompute User meeting in Göteborg, Sweden
www.simdi.se
CODE-ASTER-courses at Ingenieurbüro für Mechanik, Germany
*** SALOME and CODE-ASTER for beginners and nearly-beginners
4 days, Wed 19 Sep- Sat 22 Sep 2012
*** DYNAMIC ANALYSIS WITH CODE-ASTER
2 days, Thursday 18 Oct- Fri 19 Okt 2012
www.code-aster.de
VERI_MODE=_F( . .
STURM='OUI',
SEUIL=1E-04),
another work around is
VERI_MODE=_F(
STOP_ERREUR='NON',
),jean pierre aubry
Thanks! Some questions about result.
How can be negative result of frequence? What physical meaning?
NUMERO FREQUENCE (HZ) NORME D'ERREUR
5 0.00000E+00 0.00000E+00
4 -4.44674E-10 7.10857E-20
3 -6.28864E-10 1.48138E-19
6 7.10860E-10 2.63168E-19
2 -1.05854E-09 3.40535E-19
1 -1.13853E-09 3.18442E-19
7 6.78576E-06 1.32313E-11
8 6.04989E-05 1.36749E-09
9 6.05101E-05 1.78640E-09
10 6.08722E-05 1.49796E-09
11 6.08722E-05 2.28594E-09
12 6.84768E-05 2.10293E-09
13 1.22776E-04 4.06290E-09
14 1.22776E-04 5.10838E-09
15 1.23146E-04 5.83950E-09
16 1.23504E-04 4.89884E-09
17 1.28561E-04 2.97486E-09
18 1.79621E-04 6.14595E-09
19 1.79621E-04 5.01659E-09
20 1.80703E-04 9.49856E-09
21 1.82854E-04 5.92908E-09
22 1.85906E-04 9.98350E-09
23 1.88662E-04 8.27244E-09
24 1.89363E-04 1.29534E-08
25 1.89363E-04 9.17185E-09
26 2.05922E-04 1.22786E-08
27 2.48543E-04 1.08941E-08
28 2.48613E-04 8.85719E-09
29 2.54975E-04 1.49844E-08
30 2.55026E-04 1.86272E-08
31 2.61026E-04 1.81095E-08
32 2.61148E-04 2.19163E-08
33 2.78420E-04 1.77250E-08
34 2.78601E-04 2.16955E-08
35 2.82380E-04 1.75706E-08
36 3.27681E-04 2.41488E-08
37 3.39389E-04 3.78929E-08
38 3.39389E-04 3.82463E-08
39 3.40190E-04 3.26992E-08
40 3.54054E-04 2.78621E-08
41 4.23283E-04 5.72370E-08
42 4.23293E-04 5.56193E-08
43 4.24457E-04 3.91431E-08
44 4.24460E-04 4.49572E-08
45 5.06512E-04 4.12881E-08
46 5.06519E-04 6.67597E-08
47 5.07123E-04 9.13207E-08
48 5.07719E-04 8.90278E-08
49 5.31545E-04 2.62971E-08
50 5.46698E-04 3.41461E-08
Your frequencies are not negative but 'numerical zero'. Your system has as many rigid body modes (or mechanism-degrees-of-freedom) as You have zero-eigenfrequencies,
Markgrafenstr. 21
www.simdi.se
www.code-aster.de
As a result of calculations I got the right values of the frequencies coinciding with rhe theoretical values/ But the forms of the vibrations and the Ansys forms did not match together ? and they have wrong physical sense- steady ends of the beam are dislocated.
What' wrong?
files https://docs.google.com/open?id=0B9BlA0 … VN6TUoxd1U
#Units in mm, MPa, N
DEBUT();
#Read mesh
MAILLAGE=Mesh,
TOUT='OUI',),);
AFFE=_F(TOUT='OUI',
Material=DEFI_MATERIAU(ELAS=_F(E=66000000000,
NU=0.3,RHO=2700),);
AFFE=_F(TOUT='OUI',
MATER=Material,),);
A = 0.0001;
I_y = 8.3E-10;
I_z = 8.3E-10;
J = 14E-10;
RY = 0.005;
RZ = 0.005;
AY =1.5;
AZ =1.5 ;
SECTION='GENERALE',
#Point 1 : Fixed
DX=0.0,
DY=0.0,
DRY=0.0,
DRZ=0.0,
DRX=0.0,
DZ=0.0,),);
#Load
FZ=0.0,),);
CARA_ELEM=CARA_POU,
RESULTAT=RESU1,
RESULTAT=RESU1,
MODELE=Model,
CARA_ELEM=CARA_POU,
CHARGE=Load,);
MODELE=Model,
CARA_ELEM=CARA_POU,
CHARGE=Load,);
NUME_DDL=NU,);
NUME_DDL=NU,);
MATR_B=M,
METHODE='SORENSEN',
# PREC_SOREN=0.00005,
NMAX_ITER_SOREN=80,
VERI_MODE=_F(PREC_SHIFT=5.0000000000000001E-3,
STOP_ERREUR='OUI',
STURM='OUI',
SEUIL=1E-04),
CALC_FREQ=_F(OPTION='BANDE',
FREQ=(0.00001,100000,),
# DIM_SOUS_ESPACE=1,
# COEF_DIM_ESPACE=20,
NUME_MODE=(1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,),),);
FORMAT='MED',
RESULTAT=Resul,
#IMPR_RESU(MODELE=Model,
# FORMAT='MED',
# RESU=_F(MAILLAGE=Mesh,
# RESULTAT=RESU1,
# NOM_CHAM=('DEPL','EFGE_NOEU_DEPL','REAC_NODA','SIPO_NOEU_DEPL','FORC_NODA',),),);
#IMPR_RESU(FORMAT='GMSH',
# UNITE=38,
# RESU=_F(RESULTAT=RESU1,
# TOUT_ORDRE='OUI',),);
FORMAT='RESULTAT',
RESU=_F(RESULTAT=Resul,
VALE_MAX='OUI',
VALE_MIN='OUI',),);
FIN();Why dz,dx for N1 N2 <>0 ?
NOEUD DX DY DZ DRX DRY DRZ
N1 -2.15180E-01 2.95060E-10 -1.63310E-01 7.58946E-01 5.48746E-09 -1.00000E+00
N2 -2.15180E-01 2.95016E-10 -1.63310E-01 -7.58946E-01 6.50853E-09 1.00000E+00
tomaiilyk wrote:
I got the right values of the frequencies coinciding with rhe theoretical values;
OK. So also the mode shapes of Ansys and Code-Aster should be the same.
I do not completely understand what You mean, I just try to give some hints:
(1) You did not add the boundary condition Hold=AFFE_CHAR_MECA to the calc of Your elm matrices for the modal analysis. So the modal analysis is done for an unconstrained structure, no node is fixed to zero.
(2) modal shapes are scalable. Multiplying a modal shape with any factor unequal zero means the same modal shape. So the sign of the shape from Ansys and Code-Aster can be different.
For You next contribution: could You please post the .mess-file instead of the .comm-file? Because it contains informations which make it easier to see problems in You Code-Aster-run,
Markgrafenstr. 21
www.code-aster.de
Thanks ,Johannes. Another question. If I have multiple beams fastened together what modelisation should I use and how calculate ('A','IY','IZ','JX','RY','RZ','AY','AZ',) for each of them ?
Up!
