Code_Aster forums
Welcome on the forums. Please post in English or French.
You are not logged in. You won't be able to post until you register and log in using the top-right bar.
#1 2012-08-02 16:31:06
Ex-Guru
[SOLVED]calculating VMIS in DKT in 11.2
in 11.2, when i do the following
Code:
stat=CALC_CHAMP(reuse =stat,RESULTAT=stat,
  CONTRAINTE=(
    'SIEF_ELNO','SIPO_ELNO','SIPM_ELNO',
    'EFGE_ELNO',
  CRITERES=('SIEQ_ELNO',),
  FORCE=('REAC_NODA'),
statsup=POST_CHAMP(
  GROUP_MA=('panel',), RESULTAT=stat,
  EXTR_COQUE=_F(
    NUME_COUCHE=1,
    NIVE_COUCHE='SUP',
    NOM_CHAM='SIEQ_ELNO',
'panel' being a group of DKT
i get the following
Code:
   ! <EXCEPTION> <CALCULEL2_15>                                             !
   ! Erreur utilisateur dans la commande POST_CHAMP :                       !
   !  On demande l'extraction pour des champs n'ayant pas de "sous-points". !
what i want is the VMIS criteria at the top face of the elements
looks like i am missing something!
but i cannot figure out what!
#2 2012-08-02 17:42:03
Ex-Guru
Re: [SOLVED]calculating VMIS in DKT in 11.2
i am answering myself,
it is perfectly explained here,
http://www.code-aster.org/forum2/viewtopic.php?id=17451
thanks to the guys invaolved
once again, one never read  the documentation, and the forum, enough!
#3 2012-08-06 14:03:54
pilafa
Hi Jean-Pierre,
Since you're working with COQUE_3D, maybe you can help me with an unresolved post I did recently.
I am not able to project the results on the original 8 nodes mesh (with PROJ_CHAMP).
It is working for the displacements, but not for the stress (I have only element results for now)
I obtain this message:
Code:
   ! <A> <CALCULEL_54>        !
   ! Le paramètre:  PCONTRR  de l'option:  SIGM_ELNO  n'est pas connu des TYPE_ELEM du LIGREL:  modellin.MODELE !
   !  Champ : salomres.018.000000        !
   ! Ceci est une alarme. Si vous ne comprenez pas le sens de cette                                             !
   ! alarme, vous pouvez obtenir des résultats inattendus !                                                     !
   ! <A> <CALCULEL4_63>                                                   !
   ! On n'a pas pu projeter le champ SIGM_ELNO de la sd_resultat Solution !
   !  vers la sd_resultat salomres pour le numéro d'ordre 1               !
here's the comm:
Code:
#Pour VERSION  10
DEBUT();
# PREPROC
#quad8 mesh
mesh_1=LIRE_MAILLAGE(FORMAT='MED',VERI_MAIL=_F(VERIF='OUI'));
#Dummy #QUAD8 model to postproc
        # Will produce warnings:
        #<CALCULEL2_64>
        #<CALCULEL2_63>
modellin=AFFE_MODELE(MAILLAGE=mesh_1,
                 AFFE=(_F(GROUP_MA='plate',
                          MODELISATION='3D',),),);
mesh=CREA_MAILLAGE(MAILLAGE=mesh_1,
                    MODI_MAILLE=_F(GROUP_MA='plate',OPTION='QUAD8_9',),);
mesh=MODI_MAILLAGE(reuse =mesh,
                       MAILLAGE=mesh,
                       ORIE_PEAU_2D=_F(GROUP_MA=('plate',),),
#Create model for 3D shell structure
model=AFFE_MODELE(MAILLAGE=mesh,
                 INFO=2,
                         MODELISATION='COQUE_3D',
steel=DEFI_MATERIAU(ELAS=_F(E=210.0e9,
                            NU=0.3,
                            RHO=7800.0),);
material=AFFE_MATERIAU(MAILLAGE=mesh,
                      AFFE=_F(TOUT='OUI',MATER=steel,),);
realcst=AFFE_CARA_ELEM(
                   COQUE=(
                         _F(GROUP_MA='plate',EPAIS=0.02,VECTEUR=(1.0,0.0,0.0)),
bchold=AFFE_CHAR_MECA(MODELE=model,
                       DDL_IMPO=(
                                 _F(GROUP_NO=("h1"),DX=0.0,DY=0.0,DZ=0.0,DRX=0.0,DRY=0.0,DRZ=0.0,),  #FIXED
                                 _F(GROUP_NO=("h2"),DX=0.0,DY=0.0,DZ=0.0,DRX=0.0,DRY=0.0,DRZ=0.0,),
                                 _F(GROUP_NO=("s1"),DRX=0.0,),  #symetry
                                 _F(GROUP_NO=("s2"),DRY=0.0,),
                           #      _F(GROUP_NO=("nmid"),DRZ=0.0),  #rigid motion
                        PRES_REP=(
                                  _F(GROUP_MA=("plate"),PRES=-0.5E4,),
# SOLUTION
Solution=MECA_STATIQUE(MODELE=model,
                   CHAM_MATER=material,
                   CARA_ELEM=realcst,
                   EXCIT=_F(CHARGE=bchold,),);
# POSTPTOC
Solution=CALC_ELEM(reuse = Solution,
                 RESULTAT=Solution,
                 INFO=2,
                 REPE_COQUE=_F(NIVE_COUCHE='INF',
                               VECTEUR=(1.0,0.0,0.0,),),
                 TYPE_OPTION='TOUTES',
                 OPTION=('SIGM_ELNO','SIEQ_ELNO',),);
# Project and print
# determine / project the result fields (champ) from modified model modmod to the initial model modinit
salomres=PROJ_CHAMP(RESULTAT=Solution,
                   MODELE_1=model,        #project modes/results of this model
                   MODELE_2=modellin,);   #...to this one
IMPR_RESU(FORMAT='MED',
           RESU=(_F(
                    NOM_CHAM=('SIGM_ELNO','SIEQ_ELNO','DEPL',),
                 #   RESULTAT=salomres,
                    RESULTAT=Solution,
                    MAILLAGE=mesh,),
FIN();
Pierre
#4 2012-08-06 14:52:24
Ex-Guru
it looks like you are trying too fast to calculate the stress in the bottom face of the plates
you have to calculate in the middle plane as a first step
and then calculate another concept for the top plate, second step
and the eventually a third concept for Von Mises and the like
this is explained in
another point it seems better to use CALC_CHAMP instead of CALC_ELEM in 11.* version
#5 2012-08-06 15:19:44
pilafa
Hi Jean-Pierre.
Some comments :
- Let say that I don't want the Von Mises stress for now;
- I thought that the complicated procedure explained in the post you are referring to (I actually initiated this post) was "temporary" because version 11.2 is still in development. I switched to version 10 for this reason.
- I can calculate the correct value of stress with SIGM_ELNO (for all three position (inf,mid,sup)).
It is just a problem of projecting it back to the 8 nodes elements.
I need this because paraVIS cannot postptoc 9 nodes correctly.
Pierre
#6 2012-08-06 15:45:27
Ex-Guru
i wonder whether
the ORIE_PEAU command should not be before the quad mesh creation
and, more important,
in IMPR_RESU in MED format you should have
MAILLAGE=mesh_1, which is the original mesh
instead of MAILLAGE=mesh, which is the modified quadratic mesh
to project the results on the original mesh
#7 2012-08-08 14:15:15
pilafa
Thanks for the suggestions.
However, putting ORI_PEAU before doesn't change anything.
You are certainly right about mesh_1, but the error message is emitted just after the PROJ_CHAMP command, so correcting this doesn't solve the problem either.
Strange...
Thanks anyway!
PL
#8 2012-08-10 00:06:58
Note that the problem you have drawn our attention to in this other post (http://www.code-aster.org/forum2/viewtopic.php?id=17451) has been fixed in the unstable branch (11.2.x). So if you can afford the upgrade you should be all set.
#9 2012-08-10 11:13:38
pilafa
Thanks for the info Thomas. I will try it.
For now I am playing around with version 10.
Pierre
Powered by PunBB
© Copyright 2002–2005 Rickard Andersson
