Dear Aster users,
After meshing a model, I used Wizard (Linear elastic) on Salome-Meca to create an Aster case. An Aster branch showed up in the Object Browser (attached picture). However, I would like to delete this Aster case and go back to the stage where I can use Wizard (Linear eastic) to create a new case again. How do I delete the Aster brach from the Salome-Meca Object Browser. Thank you very much.
- ffan
I got it. Thank you.
- ffan
Hoi ffan
Interesting answer.
Could you enlighten us also?
edit:
alright, Jacopo just did that in this thread:
http://www.code-aster.org/forum2/viewtopic.php?id=19714
kind regards - kees
