I have been trying the thread provided by
http://code-aster.org/forum2/viewtopic.php?id=14348, which imports partition module to use the class MAIL_PY(). But I cannot import the partition even after I added partition module in the search folder.
Therefore, I am wondering if it is possible to get the information of the mesh,which imported by the command LIRE_MAILLAGE. This information includes the coordinates of each node in the mesh, nodes numbers , elements number as so on. What I am going to do is to use this information in a python script. Based on the node coordinates, I can automatically identify which nodes belong to a certain element. And the element numbers determine the loops.
Thank you all.
Kevin
Hoi Kevin
did you use the DEBUT(PAR_LOT='NON')?
See snippet below.
groeten
kees
DEBUT(PAR_LOT='NON');
import sys
# assume ''construct_shell_thickness'' in folder:
sys.path.append("/cae_sg500/caexample/caelinux/coque_3d/varyshth/")
cpath = sys.path
print 'length of cpath: ',len(cpath)
print 'current path: ',cpath
print 'current appended path: ',cpath[-1]
# reading initial mesh
meshinit=LIRE_MAILLAGE(FORMAT='MED',INFO=1,);
#define shell (coque_3D) model;
# we have to add centre nodes with CREA_MAILLAGE
meshmod=CREA_MAILLAGE(MAILLAGE=meshinit,MODI_MAILLE=(_F(TOUT='OUI',OPTION='QUAD8_9',),),);
from construct_shell_thickness import *
from Utilitai.partition import *
import numpy
info = 2
ThicknessGroupShell = construct_shell_thickness(meshmod,info)
kind regards - kees
Hi Kees,
Thank you for your reply.
Hoi Kevin
See snippet below.groeten
kees
Yes, I did. In your post, you still used the command:
. This issue is that I have some trouble in importing partition module. Here is a detail of the issue:http://code-aster.org/forum2/viewtopic.php?id=20909 Is there any alternative way to get the nodes coordinates straightforward. Or do you have any suggestion to solve the abovementioned problem. Thank you very much.
Kevin
Hi
I installed salome-meca at my home directory.
and I added the path for Utilitai before import.
The following example works well for me.
#-------------------------example-------------------------------------
import sys
import os
import numpy as np
sys.path.append("~/salome_meca/V2016/tools/Code_aster_stable-1260/lib/aster/Utilitai")
