I'm facing the following problem:
A beam is sliding on a fixed part without friction. The reaction forces should be the same on the moving nodes as on the fixed ones. But I get a difference:
- Y reaction force on the fixed nodes: 46.3 N
- Y reaction force on the moving nodes: 44.3 N
- normal contact force RN: 44.3 N
Where do these 2N on the fixed nodes come from? I guess I'm missing something very simple but I cannot find what.
Thank you for your help,
The comm and med files.
Compared with another software, the reaction force of the fixed nodes is similar (cf. attached picture).
Nevertheless I still can't figure out why the reaction force of the moving nodes is not the same in the CA simulation...
Exactly, I expect to get the same reaction forces on both sides.
there are warnings about the time step (=increment ?) which is not adapted
during the calculation.
The results do not seem correct as the X component oscillates from one step to another, like numerical stick-slip
Thank you for your advice. I tried with a very small time step but the results are still the same. The X force is strange indeed, it should be around 0 as there is no friction and almost no deformation of the contact surface.
maybe, but as I already use the ORIE_PEAU_2D I can't see what else I could change...
I don't think it's due to the mesh. Even with a crazy refined quadratic mesh the reaction forces do not change.
Not exactly, but close, as depicted on the attached plot.
I removed line 103 :
# DEFORMATION='GROT_GDEP',
and it works. I mean the balance of forces is correct.
then I read http://www.code-aster.org/forum2/viewtopic.php?id=18029 and it was written that for non linear calculations (either material and geometry) you must use 3D shells.
Hope it helps.
Thank you for your help bbd,
You are right, the reaction forces are not correct with C_PLAN elements and GROT_GDEP deformations ! I made a simple comparison on a beam in flexure:
1) C_PLAN and PETIT deformations: forces OK
2) C_PLAN and GROT_GDEP deformations: forces KO
3) 3D and PETIT deformations: forces OK
4) 3D and GROT_GDEP deformations: forces OK
That is not a good news as most of my calculations are C_PLAN/GROT_GDEP... I found nothing in the documentation that mentions this limitation.
I believe it is written in U2.02.01 section 2.3.2
but I agree the way it is presented is not clear.
The 'available' behaviors and laws are listed in a table but it's worth telling a few words about the risks of using this combination of asumptions (elements and calculation type) as nothing prevents us using such combinations.
According to U4.51.11 section 4.5.2 it should work...
Oui, je vais le faire.
I never closed this topic but is is solved.
There is a mandatory workaround since 2017: the following error occurs when using GROT_GDEP with C_PLAN and elastic material :
! On ne peut pas utiliser les contraintes planes en élasticité avec une !
! déformation de type GROT_GDEP. !
! Conseil: utilisez une loi élastoplastique sur laquelle vous aurez mis une !
! limite d'élasticité très grande. !
The trick is to define a non linear material with a very high yield strength, for instance :
mat01 = DEFI_MATERIAU(ECRO_LINE=_F(D_SIGM_EPSI=1.0,
SY=1e+15),
ELAS=_F(E=200000.0,
NU=0.3))
and to use the following relation in COMPORTEMENT :
RELATION='VMIS_ISOT_LINE'
