#1 2017-02-10 17:21:31
[SOLVED] Reaction forces not equal with C_PLAN/GROT_GDEP
I'm facing the following problem:
A beam is sliding on a fixed part without friction. The reaction forces should be the same on the moving nodes as on the fixed ones. But I get a difference:
- Y reaction force on the fixed nodes: 46.3 N
- Y reaction force on the moving nodes: 44.3 N
- normal contact force RN: 44.3 N
Where do these 2N on the fixed nodes come from? I guess I'm missing something very simple but I cannot find what.
Thank you for your help,
#2 2017-02-10 17:22:37
Re: [SOLVED] Reaction forces not equal with C_PLAN/GROT_GDEP
The comm and med files.
#3 2017-02-20 17:24:14
Compared with another software, the reaction force of the fixed nodes is similar (cf. attached picture).
Nevertheless I still can't figure out why the reaction force of the moving nodes is not the same in the CA simulation...
#4 2017-02-21 15:46:40
bbd
there is something I don't understand.
Your second calculation seems relevant.
Then the conclusion is the code_aster simulation is not correct, isn't it ?
#5 2017-02-21 16:17:48
Exactly, I expect to get the same reaction forces on both sides.
#6 2017-02-21 16:21:38
bbd
there are warnings about the time step (=increment ?) which is not adapted
during the calculation.
The results do not seem correct as the X component oscillates from one step to another, like numerical stick-slip
#7 2017-02-21 16:54:20
Thank you for your advice. I tried with a very small time step but the results are still the same. The X force is strange indeed, it should be around 0 as there is no friction and almost no deformation of the contact surface.
#8 2017-02-21 17:33:17
bbd
newbie question. Isn't there a pb of orientation of edges ?
#9 2017-02-22 08:20:32
maybe, but as I already use the ORIE_PEAU_2D I can't see what else I could change...
#10 2017-02-22 08:32:11
bbd
the mesh.Refine locally
#11 2017-02-22 15:52:04
I don't think it's due to the mesh. Even with a crazy refined quadratic mesh the reaction forces do not change.
#12 2017-02-22 17:50:17
bbd
exactly same values ?
#13 2017-02-23 07:40:46
Not exactly, but close, as depicted on the attached plot.
#14 2017-02-23 13:55:20
bbd
I removed line 103 :
#                                        DEFORMATION='GROT_GDEP',
and it works. I mean the balance of forces is correct.
then I read http://www.code-aster.org/forum2/viewtopic.php?id=18029 and it was written that for non linear calculations (either material and geometry) you must use 3D shells.
Hope it helps.
#15 2017-02-24 23:08:45
Thank you for your help bbd,
You are right, the reaction forces are not correct with C_PLAN elements and GROT_GDEP deformations ! I made a simple comparison on a beam in flexure:
1) C_PLAN and PETIT deformations: forces OK
2) C_PLAN and GROT_GDEP deformations: forces KO
3) 3D and PETIT deformations: forces OK
4) 3D and GROT_GDEP deformations: forces OK
That is not a good news as most of my calculations are C_PLAN/GROT_GDEP...  I found nothing in the documentation that mentions this limitation.
#16 2017-02-25 08:03:57
bbd
I believe it is written in U2.02.01 section 2.3.2
but I agree the way it is presented is not clear.
The 'available' behaviors and laws are listed in a table but it's worth telling a few words about the risks of using this combination of asumptions (elements and calculation type) as nothing prevents us using such combinations.
#17 2017-02-25 15:02:59
According to U4.51.11 section 4.5.2 it should work...
#18 2017-03-07 15:57:17
bbd
il faudrait peut-être signaler le bug ?
#19 2017-03-08 06:32:27
Oui, je vais le faire.
#20 2018-11-25 06:53:55
I never closed this topic but is is solved.
There is a mandatory workaround since 2017: the following error occurs when using GROT_GDEP with C_PLAN and elastic material :
!  On ne peut pas utiliser les contraintes planes en élasticité avec une        !
! déformation de type GROT_GDEP.                                                !
!     Conseil: utilisez une loi élastoplastique sur laquelle vous aurez mis une !
! limite d'élasticité très grande.                                              !
The trick is to define a non linear material with a very high yield strength, for instance :
mat01 = DEFI_MATERIAU(ECRO_LINE=_F(D_SIGM_EPSI=1.0,
                                   SY=1e+15),
                      ELAS=_F(E=200000.0,
                              NU=0.3))
and to use the following relation in COMPORTEMENT :
RELATION='VMIS_ISOT_LINE'
