#1 2016-09-07 12:06:01
highpressuretube
Mean stress
what is the most elegant way to calculate mean stresses for a STAT-NON-LIN calculation? Let's imagine I have lower bound stress values at t=4,0 and upper bound stress values at t= 6,0 how do I calculate the mean principal stress?
I.e. mean stress = (RESU_SIEQ_NOEU.PRIN1(t=6) + RESU_SIEQ_NOEU.PRIN1(t=4)) / 2. I just don't manage to make the Paraview calculators work.
Or do you calculate mean stresses more elegantly within code aster?
highpressuretube
#2 2016-09-07 13:01:13
PierreG
Re: Mean stress
Hello highpressure,
you can create two fields for time t=4 and time t=6 with  CREA_CHAMP(OPERATION='EXTR'). Then you can combine them always with CREA_CHAMP but with option OPERATION='ASSE'.
Pierre
#3 2016-09-08 09:47:08
highpressuretube
Re: Mean stress
Hi Pierre,
thanks for the idea. That means I would include that code after CALC_CHAMP, right? Or before? I still haven't understood 100% how aster is setting up its database.
I have experimented with Paravis in the meanwhile. Result in the picture attached. But I prefer your suggestion so I will try to follow it with the next calculation I do.
highpressuretube
#4 2017-04-19 09:18:39
highpressuretube
Re: Mean stress
Finally up to including the calculation in Aster itself, but already the firsten question arose: Which TYPE_CHAM are my results for a simple STAT_NON_LINE calculation?
