#1 2017-09-16 22:56:22
[SOLVED] AFFE_CARA_ELEM with MACR_CARA_POUTRE
I am trying to use a section mesh to be given to a beam using AFFE_CARA_ELEM. I have an old code which seems to be working without any issue. But when I write a new code, it stops execution at AFFE_CARA_ELEM. I tried comparing both the codes but couldn't get anything out of it. Can anyone look into the problem? The error that I get is as follows :
   ! <EXCEPTION> <DVP_1>        !
   ! Erreur de programmation.        !
   ! Condition non respectée:        !
   !     iisec .ne. 0        !
   ! Fichier /home/A21173/smeca/yamm_build/V2017_build/V2017_public/tools/src/Code_aster_stable-v134_smeca/bibfor/modelisa/aceapo.F90, !
   ! ligne 205        !
   ! Il y a probablement une erreur dans la programmation.        !
   ! Veuillez contacter votre assistance technique.        !
I am attaching the necessary mesh, mess and comm files.
#2 2017-09-18 17:24:16
jlf
Re: [SOLVED] AFFE_CARA_ELEM with MACR_CARA_POUTRE
The name of your section appears to be 'SEC' and not 'sect1'
JLF
PS : Need a more explicit message for a future version.
#3 2017-09-18 18:25:26
jlf wrote:
JLF
An extra pair of eyes always helps!
Yes, the message needs to be more explicit. Moreover, the NOM keyword is not even mandatory in MACR_CARA_POUTRE when used through AsterStudy.
Thanks a lot.
#4 2017-09-19 16:53:52
Johannes_ACKVA
be attentive, because MACR_CARA_POUTRE has a bug. It calculates the torsional stiffness wrongly
see here: bitbucket.org/code_aster/codeaster-src/issues/110/macr_cara_poutre-computes-wrong-jx#comment-39961503
and attached calculation case
Johannes_ACKVA
______________________________________________________________________
CODE-ASTER-courses at Ingenieurbüro für Mechanik, Germany
*** CODE-ASTER INTRO + CONTACT + MATERIAL
     09-13 October 2017
*** CODE-ASTER  DYNAMIC ANALYSIS
     30 Nov - 01 Dec 2017
#5 2017-09-19 17:18:20
Johannes_ACKVA
     09-13 October 2017
Thank you for this!
