#1 2017-10-09 16:08:13
souren
Running test case error message
Hi everyone,
I could finally install code-aster on my machine. Although I still have some doubts regarding the robustness of some of its aspects such as 'astk' (I mean I am not sure if i installed it the right way!).
Well anyway at this point I am trying to run a test case as follows:
$ cd $HOME/dev/codeaster/src
$ ./waf test -n sslp114a
and I get the following error message
<INFO> starting sslp114a
 Code_Aster execution
<INFO> prepare environment in /tmp/moosavi-moosavi-HP-Z800-Workstation-interactif.21798
<E>_FILE_NOT_FOUND path does not exist : /home/moosavi/dev/codeaster/install/std/lib/aster/Cata
                                            cpu     system    cpu+sys    elapsed
   Preparation of environment              0.00       0.00       0.00       0.00
   Total                                   0.05       0.01       0.06       0.12
as_run 1.13.1
--- DIAGNOSTIC JOB : <F>_FILE_NOT_FOUND
EXIT_CODE=4
Would you please tell me what it means that the problem is?
Souren
#2 2017-10-10 22:38:50
Re: Running test case error message
Without files or additional detail, it is quite hard to provide support.
Judging from the output you submitted, it seems like the installation of your code_aster development version was not successful (missing files in the install directory).
