#1 2018-01-25 19:25:29
filjan
MACR_ADAP_MAIL and projection stress field into refined mesh(MAJ_CHAM)
Hi Code_Aster community!
Last time I've met striking bug. I tried to refine mesh (consisting only hex/quads elements), and project existing field of stresses from previous STAT_NON_LIN. Whole .comm file was created based on zzzz175b.comm. During MACR_ADAP_MAIL function I met EXCEPTION:
   ! <S> Exception utilisateur levee mais pas interceptee.  !
   ! Les bases sont fermees.                                                    !
   ! Type de l'exception : error                                                 !
   ! Code retour incorrect (MAXI 0) : 10                                 !
Problem occurs only with 'ELGA_SIEF_R' type field (i.e. with NOEU_DEPL_R everything is ok), and ONLY with mesh-hex(with tetra everything is ok, like in zzzz175b case).
My questions are: Is it a bug, that MAJ_CHAM doesn't work with SIEF_ELGA_R and mesh-hex? Will it be improved in the next C_A version?
In the attachment you can find both meshes(hex and tetra, .comm file, and both .mess files)
regards
Filjan
#2 2018-01-31 09:00:18
Nicolas
Re: MACR_ADAP_MAIL and projection stress field into refined mesh(MAJ_CHAM)
You are right. The interpolation of fields that are located over points of Gauss is not available for hexa. See line #1182 in ProjEr_hexa.mess
Unfortunately, there is no decision to improve that at the moment.
Gérald NICOLAS
EDF R&D
Responsable du logiciel HOMARD
#3 2018-02-01 16:47:05
filjan
Thank you for reply Nicholas. I recommend add this restriction to official MACR_ADAP_MAIL documentation - it will save a lot of troubles in the future : )
regards
Filjan
#4 2018-02-10 09:21:32
Anirudh
Does that imply that hex mesh refining is not possible?
Anirudh
#5 2018-02-10 15:50:40
filjan
Anirudh wrote:
Anirudh
No. You can refine hex mesh smile just it's impossible to simultaneously project stress filed into new refined mesh.
#6 2018-02-12 17:21:58
Nicolas
Hex mesh refining is possible. See doi:10.1016/j.advengsoft.2016.07.014 for example.
But the interpolation is only available for the fields over nodes or elements but not over Gauss points.
Gérald NICOLAS
EDF R&D
