#1 2018-02-13 23:56:43
MateoMartinez123
Error reported in MED library using astk for parallel processing
Hi!
I'm using astk (version 1.13.6) tuned for parallel processing, when I run the project the below error message appears:
   ! <EXCEPTION> <DVP_97>                                  !
   ! Erreur signalée dans la bibliothèque MED              !
   !      nom de l'utilitaire : mmhmii                     !
   !              code retour : -1                         !
   ! Il y a probablement une erreur dans la programmation. !
   ! Veuillez contacter votre assistance technique.        !
The mesh formats that I'm using is .med and the reading of the mesh in the .comm files is as follows:
  COMP = LIRE_MAILLAGE(UNITE=4,
                       FORMAT='MED',
                       INFO_MED=1,
                       INFO=1,
                       VERI_MAIL=_F(APLAT=1.E-3,
                                    VERIF='OUI',),
the problem seems to be there but i cannot identify what could be.
Attached the .comm file and a capture of the astk.
Any help or hint of whats going on would be really appreciate it!!
Lots of thanks!
#2 2018-02-13 23:59:02
MateoMartinez123
Re: Error reported in MED library using astk for parallel processing
The astk screenshot
#3 2018-02-14 00:00:24
MateoMartinez123
the log message file
