#1 2018-03-13 07:47:02
Ect
[SOLVED] How to duplicate a case in Aster Study?
Dumb question: is there a way to duplicate a case or a stage?
Copy/duplicate menu entries are greyed out.
When importing from a comm file it seems to break the association with the mesh, case title on top is red.
Any hint?
Thanks,
Etienne
#2 2018-03-25 16:55:51
Re: [SOLVED] How to duplicate a case in Aster Study?
It is not currently possible to duplicate:
  • a case: this is because AsterStudy only manages one case at a time, in the same way SALOME manages only one session at a time;
  • a stage: working with stages will get improvements in the versions to come in 2018 and 2019, in the meantime, duplicating a stage involves adding it another time with "Add stage from file..." option.
Note however that you may "backup" a case, so that it may be called back later. This may prove quite handy when manually testing the influence of some parameters.
Backing-up a case is done in "History view" tab.
#3 2018-04-16 08:54:01
Ect
If I understand correctly the correct workflow is to duplicate the whole salome study if one need to make variations on mesh size, geometry or boundary conditions. Correct ?
Thank you for pointing in the "backup" feature direction, I'll see if it can help managing cases.
Etienne
