#1 2018-04-11 22:33:03
JakeZwart
Show torsional vibration in ParaVis (or other)
I am working on a torsional vibration problem.  The next step is to visualize the torsional mode shape.  I spent some time today looking at ParaVis to see how I can visualize DRX the rotational degree of freedom from the beam element.
After a while I put the results along with mesh information (IMPR_RESU) in a file of result format (ASCII) and just used a spreadsheet to plot the torsion DRX.
How would I do this directly in ParaVis?
I have attached the files in case it helps.
Jake
#2 2018-04-16 10:02:37
Re: Show torsional vibration in ParaVis (or other)
to be able to view something print it first
try this
IMPR_RESU(
	FORMAT='MED', UNITE=80,
	RESU=(
		_F(RESULTAT=modes,NOM_CHAM=('DEPL',),NOM_CMP=('DX','DY','DZ',),),
		_F(RESULTAT=modes,NOM_CHAM=('DEPL',),NOM_CMP=('DRX',),NOM_CHAM_MED='drx',),
for viewing i use Gmsh and it gives the attached view
#3 2018-04-17 02:59:41
JakeZwart
Thanks jeanpierre
Based on that and some more experimentation I used the following code snippet:
IMPR_RESU(
  FORMAT='RESULTAT',
  RESU=_F(
    IMPR_COOR='OUI',
    NOM_CHAM=('DEPL', ),
    NOM_CMP=('DX', 'DY', 'DZ', 'DRX'),
    RESULTAT=modes
  UNITE=10
This gives text output that can be copied and pasted into a spreadsheet for copying.  If I spent more time or were more clever I am sure that the plotting can be done within Salome-Meca using XmGrace.
It seems that it is not easy to do in ParaVis based on the lack of responses.
