#1 2018-06-01 21:10:05
eddie135
MOdal Analysis: creating rigid element for assigning point mass
Hi Salome-Meca users
This is my first post in which I have a question as a beginner. After searching through the forum regarding the creation of rigid elements I am still struggling to find a workaround.
I have a bracket which will be meshed as shell elements as per the Salome-meca tutorial 'How to perform a modal analysis'.
Additionally, I would like to create rigid element which is connected centrally to a series of nodes as shown attached. Here are the steps I took
Mesh Mode
1)I created a group of nodes on the circular edge.
2) Added a new node at the centre of circle and assigned this to the group above
3) Created a 0D element on this central node
AsterStudy - MOdel Definition
4) assigned a finite element for the shell elements via DKT
5) For the  0D element, I do not know what to assign? Additionally, when I select gorup of element in 'assign finite element' there is no 0D element available.
Anything suggestions or help on this topic will be greatly appreciated.
BEst Regards
Eddie
#2 2018-06-02 18:40:58
Re: MOdal Analysis: creating rigid element for assigning point mass
To assign mass to a 0D element, use M_T_D_N in AFFE_CARA_ELEM.
The image is not attached to this post so I am not sure about what exactly you want to model.
#3 2018-06-03 08:18:09
ingladisa
In AsterStudy, after read the mesh (i.e. named "mesh") you have to define a new mesh (i.e. named "MNmesh") including the added node (previously included in meshgroup "MNode"):
MnMesh = CREA_MAILLAGE(
CREA_POI1=_F(
GROUP_NO=('MNode', ),
NOM_GROUP_MA=('MNode', )
MAILLAGE=mesh
From this point your model mesh is this "MNmesh", no more "mesh".
Then, in model definition you have to include, together with the still done DKT:
model = AFFE_MODELE(
AFFE=_F(
MODELISATION=('DIS_TR', ),
GROUP_ELEM=('MNode', )
MAILLAGE=MNmesh
And define (i.e. for concentrated mass = 5.0):
AFFE_CARA_ELEM (
DISCRET=(_F(
CARA=’M_TR_D_N’,
GROUP_MA=(’MNode’),
VALE=(5.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
), _F(
CARA=’K_TR_D_N’,
GROUP_MA=(’MNode’),
VALE=(0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
To connect the MNode to the "slave" nodes (i.e. meshgroup "solide") you have two ways.
By full solid link:
load = AFFE_CHAR_MECA(
LIAISON_SOLIDE=_F(
GROUP_NO=('MNode', 'Solide')
Or by RBE3 type link:
load0 = AFFE_CHAR_MECA(
LIAISON_RBE3=_F(
COEF_ESCL=(1.0, ),
DDL_ESCL=('DX-DY-DZ', ),
DDL_MAIT=('DX', 'DY', 'DZ', 'DRX', 'DRY', 'DRZ'),
GROUP_NO_ESCL=('Solide', ),
GROUP_NO_MAIT=('MNode', )
