#1 2018-08-01 10:15:19
Stivan_Astro
How to visualize internal variables?
Hello everyone,
I perform a tensile test on a specimen with a cohesive behavior potential crack path. The results I get in terms of displacement field or stress field (SIGN component of SIEF_ELGA) satisfy me.
I have some troubles trying to visualize internal variables for the CZM_LIN_REG law over time, V2 and V3 for instance.
V2 is an indicator of dissipation   -->   =0 if linear mode, =1 if dissipative mode
V3 is an indicator of damage       -->   =0 if healthy material, =1 if damaged material, =2 if broken material
This is an extract of my command file :
EVOL = STAT_NON_LINE(
    MODELE=MO,
    CHAM_MATER=CHMAT,
    COMPORTEMENT=(
        _F(
            GROUP_MA=('SUB_1', 'SUB_2'),
            RELATION='ELAS'
        _F(
            GROUP_MA=('FISS'),
            RELATION='CZM_LIN_REG'
    EXCIT=(_F(CHARGE=FIXE), _F(CHARGE=TRACTION, FONC_MULT=coef)),
    INCREMENT=_F(INST_FIN=tfin, LIST_INST=INSTANTS),
    CONVERGENCE=_F(ITER_GLOB_MAXI=10, RESI_GLOB_MAXI=0.0001),
    NEWTON=_F(MATRICE='TANGENTE', REAC_ITER=1)
IMPR_RESU(
    FORMAT='MED',
    RESU=_F(
        RESULTAT=EVOL
        LIST_INST=INSTANTS,
        NOM_CHAM=('VARI_ELGA', ),
        NOM_CMP=('V2', 'V3'),
    UNITE=3
UNITE=3 refers to a 'vari_elga.rmed' file. In Paraview, when I load this file, I have nothing to visualize.
What is wrong?
Steven Petrowiste
#2 2018-08-01 16:53:33
Re: How to visualize internal variables?
What is wrong?
Have you applied the required filters to display Gauss point-wise fields ? That is
Filters > Mechanics > ELGA Field to ...
filling the dots with whatever filter is best suited for you :
- display as a discrete field with Point Sprite/Point Gaussion depending on your use of 2017 or 2018 version ;
- display as a scalar map with Surface.
#3 2018-08-01 20:25:20
You can alse display a special field "VARI_ELGA_NOMME" (IMPR_NOM_VARI in IMPR_RESU) that represents internal variables with their names and not with their number. It's more convenient
