#1 2018-07-31 09:16:27
MachCone
<AsterStudy> Can't see group in POST_RELEVE_T and POST_ELEM
Hi all, I am trying to create output tables using POST_RELEVE_T and POST_ELEM operators. However, I can't see the groups I have created when I am setting up these operators using AsterStudy. At the same time, the same groups can be seen and selected under the BC and Load operators. Can anyone shed some light on what is going on here?
#2 2018-07-31 20:47:01
Re: <AsterStudy> Can't see group in POST_RELEVE_T and POST_ELEM
Did you choose a model ?
These commands need to have a reference to the mesh, by the model for instance
#3 2018-08-01 17:00:21
Regarding your problem, this is a known issue referenced in the embedded help of AsterStudy:
POST_RELEVE_T command
During the edition of the POST_RELEVE_T command, the link with the mesh is not activated until the modifications of the ACTION factor keyword or the whole command are validated.
#4 2018-08-02 03:06:50
MachCone
Thank you very much for your replies, AsterO'dactyle and Thomas DE SOZA. I managed to find a way around the problem accordingly.
