#1 2018-10-10 18:15:31
marcoC
Calculate DEPL
Hello
I am new on using CodeAster and after a good while looking around I could not find out how to calculate and visualize displacement in a simple truss which I enclose. When I run the code the execution runs well, but with no results.
Could you please give me some advise?
Thanks a lot
Marco
#2 2018-10-10 20:46:15
Re: Calculate DEPL
Your comm file is a little bit strange for me. Can you post the mess and med file?
#3 2018-10-10 21:36:56
marcoC
Re: Calculate DEPL
here med file
#4 2018-10-10 21:38:38
marcoC
Re: Calculate DEPL
mesh is in med file.
marcoC
#5 2018-10-11 07:35:47
Re: Calculate DEPL
that is very strange
as i have written this example i know it should work
please post the .mess file
#6 2018-10-11 10:10:47
Re: Calculate DEPL
I found several mistakes after I ran your files. the DEBUT and FIN keyword missing, in MECA_STATIQUE you apply only gravity load and without list which stepping the loads, so the result of deformation are zero.
I strongly recommend if you are newbie rewrite the example precisely with all keyword and after the successful solution you can edit the individual part of comm file.
#7 2018-10-12 11:15:08
marcoC
Re: Calculate DEPL
The DEBUT and FIN keywords are no more compulsory, once added the list which steps the loads, the calculation succeeded. Now I have to evaluate the rightness of results.
I enclose the displacement image.
Thanks a lot,
marcoC
