#1 2018-11-21 21:40:46
[SOLVED] LONMAX error
I have a DYNA_NON_LINE simulation which runs fine. When I add the following CALC_CHAMP:
resu1 = CALC_CHAMP(reuse=resu1,
                   FORCE=('REAC_NODA', ),
                   RESULTAT=resu1)
I get this strange error:
   ! <S> Exception utilisateur levee mais pas interceptee.  !
   ! Les bases sont fermees.                                !
   ! Type de l'exception : error                            !
   ! La valeur 0 affectée à l'attribut LONMAX est invalide. !
   ! Ce message est un message d'erreur développeur.        !
   ! Contactez le support technique.                        !
Any help welcome! Comm, med and mess files attached.
#2 2018-11-22 07:29:37
Re: [SOLVED] LONMAX error
It's a bug !
It comes from the fact that you do not have loads in DYNA_NON_LINE.
Workaround: Create a null load (for example, gravity)
Sorry !
To correct in next version
https://bitbucket.org/code_aster/codeas … n-no-loads
#3 2018-11-23 06:16:53
Hello AsterO'dactyle,
thank you for your prompt answer and nice workaround which works perfectly.
Just for clarification, the LONMAX error occurs with any fields of the CALC_CHAMP command if there is no load, not only for FORCE.
#4 2018-12-12 07:22:05
