#1 2018-12-06 19:48:22
VincentMcB
Installation Salome 2016 on Ubuntu 18.04 LTS
Hi everyone,
I try to install Salome meca V2016 on a virtual computer equiped of Ubuntu 18.04 LTS
One of my contact should me to install first salome meca 2018
So i get SM V2018
For this i have install python2.7 and netstat (now net-tools) using " sudo apt-get install <appli>"
After some trials (like adding underscore on 3 datas (those who contain libstdc++) in folder /V2018/prequisites/lib) , i succesful install V2018 and run it without problems (and without running Aster module because i don't know how to use this last version of Salome meca)
So after that, i install V2016 and i can't run it without using root user !
I have to use 'sudo ./salome' in /appliV2016 else the terminal return me :
runSalome running on vincent-VM
Searching for a free port for naming service: 2812 - OK
Searching Naming Service + found in 0.1 seconds
Searching /Kernel/Session in Naming Service +++Warning: this type (Study,objref) already exists, it will be ignored.
+Traceback (most recent call last):
  File "/home/vincent/salome_meca/appli_V2016/bin/salome/runSalome.py", line 620, in useSalome
  File "/home/vincent/salome_meca/appli_V2016/bin/salome/runSalome.py", line 565, in startSalome
  File "/home/vincent/salome_meca/V2016/modules/KERNEL_V7_8_0/bin/salome/orbmodule.py", line 174, in waitNSPID
    raise RuntimeError, "Process %d for %s not found" % (thePID,theName)
RuntimeError: Process 12459 for /Kernel/Session not found
If anyone can help me !
I have to do some work on it in a few times so every day pass without a correct running of salome meca 2016 would be wasting time !
PS : I'm french
#2 2018-12-07 08:52:57
Re: Installation Salome 2016 on Ubuntu 18.04 LTS
do you really understand what you did with that?
running Salome-meca as root will probably ruin some configuration files and the worst can be expected after that
this concerns the omniORB setup
what i would do (without any guarantee of success)
delete the directory $HOME/.config/salome make a copy before
look if there is a directory root/.config/salome if yes do the same
delete altogether your fancy SM2018 installation
see if SM2016 works then
reinstall SM2018 without modifying what is in the directory
and first tell us who you are in the adhoc section of the forum
#3 2018-12-08 11:12:22
VincentMcB
Thanks Mr Aubry for your reply,
I introduce myself in the right section.
So now back to my issue :
I have uninstall all files which you have named.
I also uninstall all files concerning all salome's versions of my disk
After all, i have only " tar zxvf SALOME2016" ./SMECA_V2016_LGPL.run "
Results :
Self Extracting salome_meca V2016 Installer
Enter the salome_meca install directory [default=/home/vincent/salome_meca] :
The directory /home/vincent/salome_meca/V2016 already exists, install anyway ? [y/N] y
salome_meca is in English, do you want to be in French ? [y/N] : n
Installation of salome_meca V2016 in /home/vincent/salome_meca/V2016 ...
All good.
Done
Creating salome_meca application in /home/vincent/salome_meca/appli_V2016 ...
Installing the CatalogResources file in /home/vincent/salome_meca/appli_V2016/CatalogResources.xml
Adjusting the file : /home/vincent/salome_meca/appli_V2016/SalomeApp.xml
  File "./salome_hpc_visu_porthos.py", line 2, in <module>
    import rlcompleter,readline
ImportError: libreadline.so.6: cannot open shared object file: No such file or directory
To run the application:
$ /home/vincent/salome_meca/appli_V2016/salome
Adjusting wishexecutable /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/etc/codeaster/profile.sh
Creating symlink in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : salome -> /home/vincent/salome_meca/appli_V2016/salome
Make link in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : homard -> ../../Homard_aster-117_aster/ASTER_HOMARD/homard
Make link in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : gibi -> ../../Gibi-20008/gibi_aster.py
Make link in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : gmsh -> ../../../prerequisites/Gmsh_bin-2120Linux64/bin/gmsh
Make links in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : gpmetis
Make links in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : kmetis, pmetis, onmetis
Make links in /home/vincent/salome_meca/V2016/tools/Code_aster_frontend-20160/outils : eficas,eficasQt
replace /home/vincent/salome_meca/appli_V2016/runAppli with /home/vincent/salome_meca/appli_V2016/salome
replace /home/vincent/salome_meca/appli_V2016//CatalogResources.xml
After, i went to /salome_meca/appli_V2016/    to run "./salome" :
INFO:MainThread:Problem loading PortManager file: /home/vincent/salome_meca/appli_V2016/USERS/.omniORB_PortManager.cfg
INFO:PortManager:Problem loading PortManager file: /home/vincent/salome_meca/appli_V2016/USERS/.omniORB_PortManager.cfg
Searching /Kernel/Session in Naming Service ++++Warning: this type (Study,objref) already exists, it will be ignored.
found in 2.0 seconds
Start SALOME, elapsed time :   2.2 seconds
A short window appear few seconds before disappear.
I'm totally lost in which files or command doesn't make the software running ...
#4 2018-12-08 16:34:12
2016 is quite an old version and i do not have it on my computer right know
in the old days the command to launch salome-meca was "runAppli" not "salome"
i am not sure about 2016
why not trying to install 2018, it installed fine on my opensuse
my main advice
do not try to invent anything and follow strictly the instruction
last point
try to find out if libreadline.so.6 is installed on your system, if not install it
#5 2018-12-08 18:20:04
Volker
I had a look in my old start script for versione 2016:
The main purpose of the script was to get a bash terminal with all messages from SALOME which will not disappear suddenly:
#!/bin/sh
gnome-terminal -e "bash -c 'cd /home/vincent/salome_meca && cd appli_V2016 &&  ./salome 2>&1 && exec $SHELL'"
#6 2018-12-09 10:41:46
#!/bin/sh
i never had to do that sort of tweaking on any salome meca install
and that since the very first version around 10 years ago
strictly following the instruction did the job
is that typical of ubuntu ?
as all the installation problem posts in here refer to ubuntu
what is so special with ubuntu ?
#7 2018-12-10 21:36:08
VincentMcB
I reinstalled Ubuntu 18.04 LTS
I got <net-tools>, <python2.7>, <virtualenv>
I installed Salome meca 2016 and i run it :
vincent@vincent:~/salome_meca/appli_V2016$ ./salome
Searching for a free port for naming service: 2817 - OK
RuntimeError: Process 7888 for /Kernel/Session not found
I searched on internet and found this :
1- With Dolpĥin, I rename the directory "Python-2710" in "Python-2710-old" in /-----/salome_meca_2016/V2016/prerequisites/
2- With Konsole, I run : virtualenv /------/salome_meca_2016/V2016/prerequisites/Python-2710
3- Launch SalomeMeca
I have done this and now :
Searching for a free port for naming service: 2818 - OK
found in 1.5 seconds
Start SALOME, elapsed time :   1.6 seconds
But like yesterday, the software seems running but no window open and after few second i get the terminal open (i can use command)
I don't understand if the problem is on graphique drivers or not ....
#8 2018-12-11 09:21:40
essayer de taper cette commande dans une konsole
/opt/salome_meca-2018-1/V2018/tools/Code_aster_frontend-20180/bin/astk
le chemin de l'installation de salome meca doit être adapté
