#1 2019-02-06 04:30:10
nirmaljoshi
postprocess without re-running the whole analysis
While doing analysis for a file, I forgot to add some post processing command for data extraction (it took about 20 minutes to solve). Is it possible to rerun for the post-processing only? I mean just extract the data to output file such as reaction and displacement instead of running the solver from zero?
#2 2019-02-06 08:35:06
Re: postprocess without re-running the whole analysis
yes of course
please read my book, it is in it
keyword POURSUITE
and do not forget to introduce yourself in the ad-hoc section of the forum
#3 2019-02-06 09:33:35
with Asterstudy:
The first analysis must have been done with "Reusable" in order to keep the base.
1-2) Add a new stage with the post-processing
3-4) Run only the new stage
Asterstudy poursuite
#4 2019-02-06 10:23:49
nirmaljoshi
jeanpierreaubry wrote:
keyword POURSUITE
Seems it has been depreciated in 2018. (ref: code-aster.org/V2/doc/default/en/man_u/u4/u4.11.03.pdf)
Done!
Thanks konyaro. I will try it and let you know the outcome.
#5 2019-02-06 10:43:18
nirmaljoshi
@konyaro
I tried. But the post-processing stage (3 in your figure)  doesnot run independently because both stages get selected. When I try to deselect stage 1, the stage 2 also gets deslected. How to deselect stage1 only?
#6 2019-02-06 11:37:23
You must click on stage 2 only. If it doesn't work that means you didn't save the base of the first analysis (Reusable) and that the results of the first stage don't exist anymore.
#7 2019-02-07 09:52:27
nirmaljoshi
@konyaro: You are right but there is a small bug perhaps. In aster study, the "Reusable" checkmark appears checked by default while running the analysis but infact it is not checked during execution. We need to uncheck and recheck it again.
Thanks.
#8 2019-02-11 09:53:56
nirmaljoshi
How about extracting results from file which have terminated before full execution (for example 22 of 100 steps get executed and remaining do not execute due to convergence problem or time limit)?
