#1 2019-02-25 03:05:33
nirmaljoshi
How to visualize load in paravis?
Is it possible to visualize load in paravis? Is yes, how to do that?
#2 2019-02-25 15:00:22
Re: How to visualize load in paravis?
You might want to have a look at CONCEPT keyword in IMPR_RESU.
#3 2019-02-26 03:34:29
nirmaljoshi
I tried (CONCEPT=_F(CHARGE=load2)) but could not succeed to display. Here is the command. The screenshot of paravis and mesh is attached. Do I need to do anything in paravis too?
DEBUT(LANG='EN')
                     UNITE=3)
model = AFFE_MODELE(AFFE=(_F(GROUP_MA=('Group_concrete', ),
                             MODELISATION=('D_PLAN', ),
                             PHENOMENE='MECANIQUE'),
                          _F(GROUP_MA=('Group_rebar', ),
                             MODELISATION=('2D_BARRE', ),
                             PHENOMENE='MECANIQUE')),
                    MAILLAGE=mesh)
bar = AFFE_CARA_ELEM(BARRE=_F(CARA=('EP', 'R'),
                              SECTION='CERCLE',
                              VALE=(0.01, 0.01)),
concrete = DEFI_MATER_GC(MAZARS=_F(CODIFICATION='BAEL91',
                                   FCJ=39000000.0,
                                   UNITE_CONTRAINTE='Pa'))
steel = DEFI_MATER_GC(ACIER=_F(D_SIGM_EPSI=10000000000.0,
                               E=2e+11,
                               NU=0.3,
                               SY=400000000.0))
fieldmat = AFFE_MATERIAU(AFFE=(_F(GROUP_MA=('Group_rebar', ),
                                  MATER=(steel, )),
                                  MATER=(concrete, ))),
                         MAILLAGE=mesh,
listr = DEFI_LIST_REEL(DEBUT=0.0,
                       INTERVALLE=_F(JUSQU_A=2.0,
                                     PAS=1.0))
fload = DEFI_FONCTION(INTERPOL=('LIN', ),
                      NOM_PARA='INST',
                      PROL_DROITE='LINEAIRE',
                      PROL_GAUCHE='LINEAIRE',
                      VALE=(0.0, 0.0, 100.0, 100.0))
support = AFFE_CHAR_MECA(DDL_IMPO=(_F(DX=0.0,
                                      DY=0.0,
                                      GROUP_NO=('Group_supportNode', )),
                                   _F(DX=0.0,
                                      GROUP_MA=('Group_symSupFace', ))),
load2 = AFFE_CHAR_MECA(FORCE_NODALE=_F(FY=-50.0,
                                       GROUP_NO=('Group_loadingNode', )),
resnonl = STAT_NON_LINE(CARA_ELEM=bar,
                        CHAM_MATER=fieldmat,
                        COMPORTEMENT=_F(GROUP_MA=('Group_concrete', ),
                                        RELATION='MAZARS'),
                        EXCIT=(_F(CHARGE=support),
                               _F(CHARGE=load2,
                                  FONC_MULT=fload)),
                        INCREMENT=_F(LIST_INST=listr),
rxn = CALC_CHAMP(CONTRAINTE=('SIEF_ELNO', ),
                 RESULTAT=resnonl)
IMPR_RESU(CONCEPT=_F(CHARGE=load2),
          FORMAT='MED',
          RESU=(_F(RESULTAT=resnonl),
                _F(RESULTAT=rxn)),
          UNITE=2)
#4 2019-02-26 09:07:56
in document U7.51.21, Procedure IMPR_RESU (FORMAT 'MED')
there is a list of what can be printed as CONCEPT in a .med file
FORCE_NODALE is not in that list
in my book there is a solution to print this load as a vector
#5 2019-02-26 12:14:26
nirmaljoshi
Thanks for reply.
@jeanpierreaubry
I guess you meant  U7.05.21. Actually i had read the documentation before posting the question but I missed to read the section 6.2 of the manual. Anyway, thanks!
Could you please tell me in which chapter of your book is the process described?
#6 2019-02-26 14:22:54
yes u7.05.21
maybe yo can read the table of content it is named "showing the applied load"
#7 2019-02-26 15:18:35
nirmaljoshi
@jeanpierreaubry
Thanks for the direction. The book mentions procedure for GMESH, so I am not sure if works in paravis. I will test and post soon.
#8 2019-02-26 15:21:29
NO and NO it mention how to produce a .med file
after that how to process this med file depends on the viewer Gmsh or Paravis
#9 2019-02-27 07:01:27
nirmaljoshi
@jeanpierreaubry
Yes, I meant the same i.e. the book mentions on how to process in Gmsh only.
Referring to your book, I can process file in CodeAster. But in paravis, I could not do properly. I (1) generated vectors (2) filter>common>wrap by vectors. The result is not good. (see attachment)
Moreover, I could not print applied force (FORCE_NODA perhaps?), only the reaction force gets printed.
@dbpatankar
Had you succeeded on doing it ? Any sample file?
#10 2019-02-27 07:50:55
i do not understand what your attached image means (no title, no explanation!)
i expect it can be done in Paravis
probably in the usually utterly complicated way
and it can be done in gmsh
and in a straightforward way
and that is enough for me
by the way it is a vector nodal field
#11 2019-02-27 08:06:16
the warp_by_vector filter is for visualization of deformed structure not for visualization of "vectors".
#12 2019-02-27 08:51:16
nirmaljoshi
Thanks for the reply.
@mecour
Completely agree with you, it happened because I could not find any other method except the familiar word "vector". Anyway, do you know how to display the "vector nodal field" in paravis as mentioned by jeanpierreaubry?
@jeanpierreaubry
In the last attached figure, the left one is the input structure and the right is the post-processed view in paravis. I thought you could easily recognize it.
Anyway, since the use of code_aster with salome_meca is more user-friendly (at least for me!), I will probably stick with this combo package for a while until I get more "cleverer". And since this package's default post-viewer is paravis, i am trying to explore it, even-though I know it is another huge mountain to climb!
