#1 2019-02-18 14:55:37
chenghui62000
How to run ASTK independently?
Dear all,
Recently, I have found that ASTK is a very good module to do the simulation. However, the newest version (V2018.0.1) does not provide ASTK on the toolbar. I have to first start the "Asterstudy", and then Run "Astk" from Tools-Plugins-code_aster.
How do you think of this? and any advice to open ASTK more efficiently?
Hui Cheng
#2 2019-02-18 15:33:01
GPSalachs
Re: How to run ASTK independently?
I think you have to install code_aster as a standalone to run ASTK independently. There are a couple of tutorials in youtube that explain step by step how to do that.
#3 2019-02-18 16:30:41
this is explained in my book
i also explaine how to handle ASTK
in fact i use code_aster only this way
#4 2019-02-20 23:19:33
chenghui62000
Hi, Jean Pierre Aubry and GPSalachs
Thank you for your reply, I am trying to install the code_aster independently according to one YouTube tutorials. The reference link is as below:
" http://www dot youtube dot com/watch?v=HQTiy3ixNro&t=1118s"
The question is that: After I source the profile.sh using this command in the terminal:
source /opt/aster/etc/codeaster/profile.sh
I can run ASTK when I type the name in that terminal, but it could not work in a new terminal.
Is there a good solution to run the ASTK in a new terminal without using the above source... code again?
Hui Cheng
#5 2019-02-21 08:26:59
jlf
Hello
To run only ASTK, the simplest way is to install "salome_meca" and run salome in shell mode with astk
/your/install/path/SALOME-V8.5/appli_V8_DEV/salome shell -- astk
JLF
#6 2019-02-21 08:27:10
why not installing code_aster using the code_aster site instruction
is this youtube video a more trusted information
in eleven year i never had to do that
#7 2019-02-26 15:41:09
chenghui62000
Thank you all for your help. I have to say, that ASTK is quite useful to create the calculation environment. For now, I am usually using ASTK to generate the .export file, and then use "as_run" in the terminal to do the simulation.
