#1 2019-03-12 13:55:01
chenghui62000
Question on output the results using "IMPR_RESU"
Dear all,
There is a question about how to output the results file.
Currently, I used the DYNA_NON_LINE solver to solve the dynamic equation of my study object-- a cage net. The flow chart of my calculated method is shown below. I output the results using "med" format and want to use the "ParaVis" to processing the results to see the dynamic response depended on the time. However, I can not get the time historical results. I guess it is due to the  changing name when calling the DYNA_NON_LINE solver:
resn[k] = DYNA_NON_LINE(CARA_ELEM=elemprop,
Is there any way to get the animation of the dynamic response of the structure using the med format? if not should I change it to other kinds of format, or i need to write a script to do that?
Flow%20chart%20of%20codeaster.png?raw=true
best regards,
Hui Cheng
#2 2019-03-12 17:10:57
Re: Question on output the results using "IMPR_RESU"
well, in this case it would be better to use 'reuse=resn' inside DYNA_NON_LINE; than using resn[k] as an array.
#3 2019-03-13 08:04:10
i think it is possible to ASSEmble the results from you array
with the operator CREA_RESU (doc U4.44.12)
with the keyword ASSE
and the use this new result to print a med file
