#1 2019-06-04 11:32:53
bhattarai
Calculation of right Cauchy-Green strain [Solved]
Dear Developers and experts,
I needed the right Cauchy-Green strain tensor for the introduction of a new material model.
I found nmgeom.F90 calculates the deformation gradient. But when I make an output (AS CALL  FLUSH) of
the deformation gradient [F] matrix and cauchy green strain tensor as C = transpose (F)*F, they are always an identity matrix at each time step with proper iteration. I was wondering why it is not updated with increased load and obvious deformation at the end of the simulation. Can anyone hint on this?
Also, I created a separate file to compute the matrix with following procedure:
! updated strain {E} in vector form
    eps(1)=deps(1)+epsm(1)
    eps(2)=deps(2)+epsm(2)
    eps(3)=deps(3)+epsm(3)
    eps(4)=deps(4)+epsm(4)
    eps(5)=deps(5)+epsm(5)
    eps(6)=deps(6)+epsm(6)
!modifying shear terms of the strain {E}
    do i = 1, 3
        epstot(i)=eps(i)
        epstot(3+i)=eps(3+i)/sqrt(2.d0)
    end do
! symmetric right cauchy green tensor {C} = 2{E} + {I} in vector form
        c11 = 2.d0*epstot(1)+1.d0
        c22 = 2.d0*epstot(2)+1.d0
        c33 = 2.d0*epstot(3)+1.d0
        c12 = 2.d0*epstot(4)
        c13 = 2.d0*epstot(5)
        c23 = 2.d0*epstot(6)
Here the components of the matrix is different and not unit matrix. can anyone provide
some light how to verify if the calculation of the {C} is correct or not?
Many thanks.
Bhattarai
#2 2019-06-04 14:01:37
bhattarai
Re: Calculation of right Cauchy-Green strain [Solved]
Part of the time increment is attached here.
#3 2019-06-11 10:02:44
bhattarai
Hello again,
I am wondering if my question does not fit to the Code_Aster development part of the forum. Can anyone put light on my question please?
Thank you again in advance.
Bests,
Bhattarai
#4 2019-06-12 19:39:48
If you want to compute large strains (gradient F or Cauchy-Green tensor) you have to set "large" flag to .true. (parameter of nmgeom)
In code_aster, when you set DEFORMATION='GROT_GDEP' or 'SIMO_MIEHE', it's the case.
Where are you in the code ?
#5 2019-06-24 14:34:30
bhattarai
Hi AsterO'dactyle,
My apologies for late reply. I set the parameter grand to .true. in geom.F90 and in my implementation file as,
       call nmgeom(ndim, nno, axi, .true., geom,&
                  kpg, ipoids, ivf, idfde, depl,&
                  ldfdi, poids, dfdi, f, eps,&
                  r)
but got an error:
Error: Type mismatch in argument ‘grand’ at (1); passed LOGICAL(8) to LOGICAL(1)
Bhattarai
#6 2019-06-24 20:37:51
aster_logical is boolean(kind=1)
So, set .true._1 instead of .true.
#7 2019-06-25 11:03:31
bhattarai
Thank you AsterO'dactyle. The error is solved now, but got another problem which I shall post creating a new thread if I am not successful to solve it by myself.
Bhattarai
