#1 2019-06-28 03:30:57
AliF
Problems with installing code_aster using cygwin
Hello, my English is not very good, please understand.
I use cygwin to install code_aster on windows, using the python command
python setup.py --prefix=/home/Administrator/dev/codeaster_install
There was a problem during execution
Checking for max command length...   32768
Checking for file... /usr/bin/file
Checking for ar... /usr/bin/ar
Checking for architecture... CYGWIN_NT-6.1-7601 / posix / x86_64
Checking for number of processors (core)... 4
Checking for Code_Aster platform type... LINUX64
Checking for bash... /usr/bin/bash
Checking for Python version... 2.7.16
Checking for gcc... /usr/bin/gcc
Checking for /usr/bin/gcc configured installation directory... /usr/lib/gcc/x86_64-pc-cygwin/7.4.0, /usr/bin
Checking for libpthread.lib... no
Checking for libz.lib... no
Checking for libdl.lib... no
Exception raised. See 'setup.log' file for details.
Why is a .lib file instead of a .so file? Ask me where is the problem? Thank you very much
#2 2019-06-28 03:49:01
AliF
Re: Problems with installing code_aster using cygwin
The error log file is in the attachment, please help me to see, thank you
#3 2019-06-28 13:36:47
the corresponding line for a successful installation on opensuse are like this
Checking for libpthread.so... /usr/lib64/libpthread.so
Checking for libz.so... /usr/lib64/libz.so
Checking for libdl.so... /usr/lib64/libdl.so
this means that the named libraries are not installed
i expect you are going to have a lot more like this
as having these basic libraries not installed is most uncommon to my opinion
which distribution is installed?
#4 2019-07-04 09:21:38
AliF
jeanpierreaubry wrote:
I am sorry to see it now.
I tried adding a log in setup.py and found this in as_setup.py:
if sys.platform in ("win32", "cygwin"):
          self._ext_static = self._ext_shared  = '.lib'
I think this is why it is a lib instead of a so file.
I changed this statement to:
          self._ext_static = self._ext_shared  = '.so'
but it still report same error,it can't find libpthread.so .
I found only one libpthread.a in cygwin.
So, I changed the statement to '.a',but it still didn't work.
Then I added the log and found that the environment variable might be wrong. I changed the environment variable, but it still didn't work.
Have you compiled under cygwin? I don't know if anyone has successfully compiled with cygwin, which has been bothering me for a long time.
Thanks to all those who answered my question.My English is not very good, please forgive me.
#5 2019-07-16 03:35:08
AliF
Hello everyone, I am using cygwin to install, the previous problem I solved by modifying check_compilers.py and as_setup.py,
in check_compiiles.py and as_setup.py:
I changes
to
          self._ext_static = self._ext_shared = '.a'
and in as_setup.py, I changes
chk = self.check_type(self._last_found, typ=typ)
to
chk=True
Now, the installation program began to compile the various libraries in the SRC folder, now there are new problems, the new problem is another In a topic
