#1 2019-07-11 17:20:15
chenghui62000
How to switch off the log file writing on disk
Dear all,
I have a high leave question (at least for me) for the Code_Aster files management system.
First, please see a snapshot of the folder on my computer. (It is a temp folder for my specifical simulation)
FluxBB bbcode test
There is a very large file in this folder: fort.6 which I think is a temporary message file (.mess file).
And this file becomes larger with the simulation going.
The question is that: since I did not add the following line in the to the .export file to save the message file(see the attached file). Why this file still comes out on my computer? Can I enforce the fort.6 file not writing on my disk?
The 'tempt message file' eats a lot of space on my limited disk. And the situation becomes even worse when I run several simulations on the cluster simultaneously because we only have 4Gb individually.
mess /home/hui/Documents/AllCodeRepository/coderepository/CodeAsterModule/inputfilescreator/mess.log R  6
In addition, I didn't find any documentation to explain the .export file, could you please give some learning links?
Hui Cheng
#2 2019-07-14 13:25:11
chenghui62000
Re: How to switch off the log file writing on disk
Dear all,
I have found that I can delete the fort.6 file in manually and it won't come out.
Because my calculation uses a python loop to assign the forces on a large number of nodes. The log file could be extremely huge.  When I run several cases simultaneously the disk will be eaten up.
By the way, removing the fort.6 file manually can be a (possible) solution to my previous question:
https://www.code-aster.org/forum2/viewtopic.php?id=24208
#3 2019-07-14 15:19:35
i solved likewise problem in id=23083
this implies setting the AFFE_CHAR_MECA in a separate file with INCLUDE in the main.comm file
#4 2019-07-14 22:18:42
chenghui62000
Hi Jean Pierre,
Thank you for your reply. It is very exciting for me. Could you please give more hints for that? For example, the id=23083 means? and how to use INCLUDE  in the main comm file?
Thank you very much!
Hui Cheng
#5 2019-07-15 08:05:11
chenghui62000 wrote:
the id=23083 means?
this is the id of the post
t
there is an example in chapter 18 in my book
#6 2019-07-15 10:00:38
chenghui62000
Hi Jean Pierre,
I could not find the id=23083 post on this forum. Could you please share the link here?
Thank you very much for the knowledge sharing in your book chapter 17-19. It is very useful.
I will try this INCLUDE method for my cases.
Hui Cheng
#7 2019-07-15 14:33:23
/forum2/viewtopic.php?id=23083
id=23083 is there another way to write it???????
#8 2019-07-16 08:52:23
chenghui62000
Great! I should find it earlier.
#9 2019-07-31 21:20:11
chenghui62000
This question has been solved, but I have found that the "INCLUDE" will be removed in version 15. What a pity.
By the way, do you know how to turn off the Alarm message? I found that it always reminds as following:
   ! <A> <SUPERVIS_25>                                                              !
   ! L'usage de la commande INCLUDE n'est pas conseillé.                            !
   ! Une étude utilisant la commande INCLUDE ne peut pas être éditée en mode        !
   ! graphique dans AsterStudy. Il est alors conseillé de remplacer INCLUDE par     !
   ! un "Stage" supplémentaire.                                                     !
   ! De plus, cette commande ne sera plus disponible à partir de la version 15.     !
   ! S'il s'agit d'exécuter des commandes Python, il sera alors possible d'utiliser !
   ! l'instruction "import".                                                        !
   ! Ceci est une alarme. Si vous ne comprenez pas le sens de cette                 !
   ! alarme, vous pouvez obtenir des résultats inattendus !                         !
Thank you so much
Hui Cheng
#10 2019-07-31 22:45:29
Anirudh
To turn off alarms that you are definitely sure of, just include this statement in the DEBUT() command at the top of comm file:
DEBUT(IGNORE_ALARME=("SUPERVIS_25","DISCRETE_26" ...etc..) )
Anirudh
#11 2019-08-01 10:44:43
hello Anirudh
it should read IGNORE_ALARM and not IGNORE_ALARME
automatic translation stroke again!!
#12 2019-08-01 17:37:02
chenghui62000
Thank you very much.
It makes my program better.
Hui Cheng
