#1 2019-07-17 14:04:32
Anirudh
salome meca fails on resuming closed study
I use Salome meca for various design work. The issue is sometimes when I open a saved study(that may or may not have errors),
it shows an error dialog box and I can't click any of the buttons on it. Neither can I click YES, NO or CANCEL. All I can do is close it from the top left X button, then again another one opens, and this time I can't even close it from there. All I can do is just kill salome meca from system monitor/terminal using PID.
Please how can I get rid of this error.
One other issue is that when I dump study that contains Asterstudy component, and load that dumped script, it hangs again.
If the asterstudy version is set to default so that no dialog box opens to ask the version of asterstudy, its ok, but If this option is set to ask in Preferences, it hangs in loading script.
I attach these errors in a video capture here.
Thanks a lot.
Anirudh
#2 2019-07-18 04:10:32
Anirudh
Re: salome meca fails on resuming closed study
This error seems to be resolved after resetting the preferences to Default in salome preference dialog box.
Anirudh
