#1 2019-07-24 11:41:29
Anirudh
[Solve]MPI Code_aster 14.2 processes are not killed on Clean interrupt
Hi to all,
I am using MPI version of CA14.2.
However, when I have to cancel a run, I try to use clean interrupt from ASTK. When I do that, the XTERM window is still always open and neither the processors are discharged. I have to manually kill XTERM window and kill aster processes from terminal using PID.
In the previous version(13.4), even when I cancelled XTERM window only, all the processes were killed automatically and the cpus were discharged.
What to do?
Thanks.
#2 2019-07-25 16:18:49
Anirudh
Re: [Solve]MPI Code_aster 14.2 processes are not killed on Clean interrupt
When i try to run an export file using
/home/anirudh/code_aster/bin/as_run 1.export
I get this error below:
<F>_PROFILE_COPY   error during copying 1.export to /tmp/astk_anirudh/anirudh-anirudh-profil_astk_5443
message : cp: cannot stat '1.export': No such file or directory
If someone can tell whats wrong?
Anirudh
#3 2019-07-25 16:23:11
Anirudh
I solved above error with this command below.
pids=$(pgrep aster) && kill -s USR1 $pids
and to solve the second problem, I first need to cd into the directory containing export file.
Anirudh
