#1 2019-07-28 19:24:45
manueloliveira
Problem installing Salome-Meca 2018 in Ubuntu 18.04
Hello to all,
I am a new user of Salome-MECA
I have downloaded the file and extracted it according to what says in the download page.
When I ./salome_meca-2018.0.1-LGPL-1.run the following error message appears.
Self Extracting salome_meca V2018.0.1_public Installer
Enter the salome_meca install directory [default=/home/pc/salome_meca] :
salome_meca is in English, do you want to be in French ? [y/N] : N
Installation of salome_meca V2018.0.1_public in /home/pc/salome_meca/V2018.0.1_public ...
All good.
Done
./create_appli.sh: line 108: /salome_prerequisites.sh: No such file or directory
Creating salome_meca application in /home/pc/salome_meca/appli_V2018.0.1_public ...
python: can't open file '/salomemeca_custom_appli.py': [Errno 2] No such file or directory
Warning: the directory /opt/ThirdParty-6/platforms/linux64Gcc/gperftools-svn/lib is in a path variable but does not exist
Warning: the directory /opt/ThirdParty-6/platforms/linux64GccDPInt32/lib/openmpi-system is in a path variable but does not exist
Warning: the directory /home/pc/OpenFOAM/pc-6/platforms/linux64GccDPInt32Opt/lib is in a path variable but does not exist
Warning: the directory /opt/site/6/platforms/linux64GccDPInt32Opt/lib is in a path variable but does not exist
Warning: the directory /opt/ThirdParty-6/platforms/linux64GccDPInt32/lib is in a path variable but does not exist
Warning: the directory /opt/ThirdParty-6/platforms/linux64Gcc/gperftools-svn/bin is in a path variable but does not exist
Warning: the directory /home/pc/OpenFOAM/pc-6/platforms/linux64GccDPInt32Opt/bin is in a path variable but does not exist
Warning: the directory /opt/site/6/platforms/linux64GccDPInt32Opt/bin is in a path variable but does not exist
To run the application:
$ /home/pc/salome_meca/appli_V2018.0.1_public/salome
Adjusting wishexecutable /home/pc/salome_meca/V2018.0.1_public/tools/Code_aster_frontend-201801/etc/codeaster/profile.sh
Final configuration
It says that the application was installed but I have no file called salome in the folder $ /home/pc/salome_meca/appli_V2018.0.1_public.
Can anyone give me a hand with this?
Best Regards!
#2 2019-08-02 18:59:04
manueloliveira
Re: Problem installing Salome-Meca 2018 in Ubuntu 18.04
So,
I was using Ubuntu 18.04. I downgraded to 16.04 and it worked correctly.
#3 2019-08-06 22:56:37
solver
Exact same problem using Ubuntu 19.04.
#4 2019-08-06 23:32:32
solver
I have tried Salome-Meca 2017.0.2 on Ubuntu 19.04. Same problem.
#5 2019-08-07 21:32:06
solver
Searching through the forum revealed that this problem has been solved before.
Before running '$ ./salome_meca-2018.0.1-LGPL-1.run' to install Salome_Meca you can do a quick python environment change, running these lines
export PATH=/usr/bin:$PATH
alias python=/usr/bin/python2.7 (or whatever is the name of your Python2 executable)
unset PYTHONPATH
export PYTHONHOME=/usr
The installation script relies on python 2 not 3 which was my case. The install is now without errors, but salome didn't start. Go to install directory "$HOME/salome_meca/V2018/prerequisites/debianForSalome/lib", find 3 files named "libstdc++" and rename them to "_libstdc++".
This procedure worked for me with nvidia graphics on Ubuntu 19.04.
#6 2019-08-16 14:58:05
kathi
hello,
I have exactly the same problem with Ubuntu 18.04 as manueloliveira. I tried the exact commands given by solver, but afterwards there is the same problem with the installation of SalomeMeca
solver, can you help me please? I suppose the commands which you propose will work if slightly adapted to my system, but I don t know how.
was OK, because this is the right place on my system
thank you, best regards
kathi
