#1 2019-10-21 17:51:29
sblanco
[SOLVED] Error instaling code-aster in ubuntu 18.04 (virtualbox image)
I am having problems installing code-aster 13.8 in an ubuntu 18.04 machine. After checking the prerequisites I get the following error:
Checking for dependencies and required variables for '__main__'...     [  OK  ]
Checking for dependencies and required variables for '__cfg__'...      [  OK  ]
Filling cache...                                                       [  OK  ]
Check if found values seem correct. If not you can change them using 'setup.cfg'.
  File "setup.py", line 945, in <module>
    main()
  File "setup.py", line 868, in main
    should_continue()
  File "/home/alumno/Downloads/aster-full-src-13.8.0-1.noarch/aster-full-src-13.8.0/as_setup.py", line 142, in should_continue
    resp=input(question)
  File "<string>", line 1, in <module>
NameError: name 'y' is not defined
Has anyone got samething similar? Any help will be much appreciated.
Best regards and thank you very much,
Sergio
#2 2019-10-22 19:58:51
Re: [SOLVED] Error instaling code-aster in ubuntu 18.04 (virtualbox image)
Python3 ?
#3 2019-12-04 18:27:34
sblanco
Hi, thanks for you reply.
You were right, everything worked fine with the command:
python3 setup.py install
Thank you!
Best wishes,
Sergio
