#1 2019-12-02 09:22:07
Mahions
How to import node temperature?
I want to import many node temperature values for thermal expansion.Do you have any cases about that?
Thanks in advance for your help.
#2 2019-12-04 10:21:42
Mahions
Re: How to import node temperature?
Here is my model. The temperature field is as follows:
height(mm)(Z axis)     mark1(K)   mark2   mark3    ...      mark12
    -380                               **             **            **        ...         **
     588                               **             **            **        ...         **
How to import such a temperature field for thermal expansion?
Thank you very much.
#3 2019-12-04 12:46:54
GPSalachs
having a similar problem i found these threads quite helpfull : /viewtopic.php?id=21214 , forum2/viewtopic.php?id=24578 .
Maybe the second one is closer to what you are looking for.
#4 2019-12-06 02:35:13
Mahions
I think DEFI_NAPPE can solve my problem, but I can't find parameter 'radian'. How to define local cylindrical coordinate system? So ,temperature depends on two parameter 'Z’ and 'radian'(which is not in the parameter).
