#1 2019-12-02 10:05:58
rad.mo
Problem avec la bibliothèque MED
I have this error message running a simple problem:
JDC.py : ERREUR WITH THE EXECUTION - INTERRUPTION
>> JDC.py: DEBUT CR of execution of JDC in MIXTE
   ! <S> Exception user raised but not interceptee. !
   ! The bases are fermees.                         !
   ! Type of the exception: error                   !
   ! Erreur signalée dans la bibliothèque MED       !
   !      nom de l'utilitaire : mmhmii              !
   !              code retour : -1                  !
I am using  ASTK from Salome_Meca 2018.0.1,     and I am using gmsh 4.4.1 to creat .MED file.
Any known compatibility problem?
I will gratefully appreciate your help.
Best regards.
#2 2019-12-14 05:54:32
Re: Problem avec la bibliothèque MED
you probably saved your mesh in MED version 4 but CA 2018 can only read MED version 3. You can update to Salome-meca 2019 which can read MED version 4.
#3 2020-01-06 09:01:33
rad.mo
thank you  konyaro,
