#1 2019-12-03 19:16:13
marcelo
[SOLVED] Augmentez le temps CPU
I'm trying to perform an impact analysis, but... it shows the following error after a while:
   ! <S> Exception user raised but not interceptee.                           !
   ! The bases are fermees.                                                   !
   ! Type of the exception: ArretCPUError                                     !
   !    Arr?t par manque de temps CPU au num?ro d'instant < 46 >              !
   !       - Temps moyen par pas de temps        : 16.410639                  !
   !       - Temps restant                       : 15.457097                  !
   !    La base globale est sauvegard?e. Elle contient les pas archiv?s avant !
   ! l'arr?t.        !
   !    Conseil :                                                             !
   !       - Augmentez le temps CPU.                                          !
I have attached the .mess file.
I will be very grateful for anyone who can help me.
#2 2019-12-03 22:09:12
dpeinado
Re: [SOLVED] Augmentez le temps CPU
When you launch the solver there are two controls: memory and CPU time. I think that the default maximum CPU time are 15 minutes. Probably your study takes more time than that. I think you should increase this limit.
#3 2019-12-03 22:09:35
GPSalachs
You have to give it more time to perform the calculation.
#4 2019-12-04 02:07:36
marcelo
