#1 2019-09-06 13:04:39
Support Wanted :Terminal Command to Install Code Astar in Ubuntu 18.04
aster-full-src-13.6.0-1.noarch.tar.gz
I have downloaded above file and Extract it. First time user of code aster. as i am excited to solve some complex mechanics problems.
Since i am not expert in understand the Readme and other files for Full Installation.
I kindly request community to give me full command list.
I have downloaded all prequities and my 18.04 is updated.
waiting for your reply. thanks in advance.
#2 2019-09-06 14:49:09
Re: Support Wanted :Terminal Command to Install Code Astar in Ubuntu 18.04
my book freely downloadable here
framabook.org/beginning-with-code_aster/
contains some instructions about how to install code_aster
but there is not much more than the detailed instructions given in the download pages of this site
should i say that if you are not ready to go through the installation steps you are probably not ready to to solve some complex mechanics problems in finite element analysis
#3 2019-09-07 07:25:37
Respected Sir,
I am not software engineer thus facing difficulty, By Theory Formulas i can solve mechanical problems. Already Using Elmer, but want to go understand code aster looking to its capability.
Anybody can give Clear Reply, How to Install Code aster in ubuntu 18.04....From Terminal ..
A Forum defines Success of Software, If Forum cannot  solve newcomer difficulty, then Code Aster cannot get New Users.
#4 2019-09-07 07:49:24
it looks like a few hundreds of people installed code_aster with the instructions given on this site pages
they most probably were not software engineer, neither was i when i did my first install about 12 years ago
and if anything goes wrong during installation the forum is here to help
as for the very start of the installation i cannot say more than what i said in my previous post
it is not that difficult when one follows the instruction
#5 2019-09-07 08:41:04
youtube has some installation videos
video is helpful
wwwdotyoutubedotcom/watch?vequaltoHQTiy3ixNro
#6 2019-09-07 14:41:30
Installation of scotch 6.0.4 successfully completed
Compiler variables for astk (set as environment variables):
export               CC='/usr/bin/gcc'
export           CFLAGS='-O2 -fno-stack-protector -fPIC'
export       CFLAGS_DBG='-g  -fno-stack-protector -fPIC'
export    CFLAGS_OPENMP='-fopenmp'
export              CXX='/usr/bin/g++'
export           CXXLIB='-L/usr/lib/gcc/x86_64-linux-gnu/7 -lstdc++'
export          DEFINED='LINUX64  _USE_OPENMP'
export              F90='/usr/bin/gfortran'
export         F90FLAGS='-O2 -fPIC'
export     F90FLAGS_DBG='-g  -fPIC'
export      F90FLAGS_I8=' -fdefault-double-8 -fdefault-integer-8 -fdefault-real-8'
export  F90FLAGS_OPENMP=' -fopenmp'
export        FFLAGS_I8=' -fdefault-double-8 -fdefault-integer-8 -fdefault-real-8'
export               LD='/usr/bin/gfortran'
export   LDFLAGS_OPENMP=' -fopenmp'
export          MATHLIB='/usr/lib/x86_64-linux-gnu/liblapack.a /usr/lib/x86_64-linux-gnu/libblas.a'
export         OTHERLIB='-L/usr/lib/x86_64-linux-gnu -lpthread -L/usr/lib/x86_64-linux-gnu -lz'
# Environment settings :
Checking for dependencies and required variables for 'astk'...
        TERMINAL is required by 'astk' but not set.
        [FAILED]
Exit code : 1
Exception raised. See 'setup.log' file for details.
sameer@sameer-desktop:~/Downloads/aster-full-src-13.6.0$
HOW TO SOLVE ABOVE ERROR..REFER ATTACHMENT FOR SETUPLOG
#7 2019-09-07 16:05:14
dont you think this thread is in the wrong section of the forum,
there is a dedicated section with code_aster installation
#8 2019-09-07 16:13:24
this what i can read from the provided setup.log file
you typed
/usr/bin/python setup.py install --prefix//home/sameer/Downloads/aster compile file
in the terminal
setup-log says
action : only 'install' or 'test'.
maybe compile and file are unknown argument
by the way i have never such a setup.log file
again why do not you follow the instruction on the code aster page in this site?
#9 2019-09-08 10:46:01
Dear Guru,
If you are EXPERT, why don't you Give Command line to install....have you read command line of code aster...please reply ANSWER AND NO UNNECESSARY COMMENTS.
#10 2019-09-08 13:59:08
usually in this section of the forum
people introduce themselves telling the other members who they are, their backgroung ....
before putting requirement to a member trying to help them
#11 2019-09-08 15:27:56
Anirudh
With this attitude you are not going very far with Code Aster.
With Code Aster you have to think like a coder and you must have patience and perseverance and ofcourse be polite.
If you are beginning with Code_Aster, using code aster directly might be a bad idea. You can first try using Salome_Meca which uses Code Aster solver.
It seems you are missing Xterm Terminal. Try installing Xterm.
#12 2020-01-14 00:04:19
MrSnail
You can try Code Aster for Windows first, if still strugling
It is a perfect start since u dont need to get used to Linux. Some features missing but they are not for beginers anyway.
https://code-aster-windows dot com/download/
