I am analysing cylinderical pressure vessel and code aster give the below message and the study was failed. Can you help me, please?
JDC.py : ERREUR WITH THE EXECUTION - INTERRUPTION
>> JDC.py: DEBUT CR of execution of JDC in MIXTE
! <S> Exception user raised but not interceptee. !
! The bases are fermees. !
! Type of the exception: error !
! Solver MUMPS: !
! The solution of the linear system is too vague: !
! Computed error: 5.65326e-06 !
! Acceptable error: 1e-06 !
! (RESI_RELA) !
! Advices: !
! One can increase the value of the key word SOLVER/RESI_RELA. !
Samet
! Solver MUMPS: !
! (RESI_RELA) !
! Advices: !
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Best regards,
Samet
At analysis section, I find RESI RELA which is in the Solver menü and then i change 1e-5 from 1e-6. The analysis is successful.
if you change the RESI_RELA to 1e-05 it works but I don't know why it doesn't converge with 1e-06.
p.s. Sorry, I didn't read your second message your wrote in the meanwhile.
if you change the RESI_RELA to 1e-05 it works but I don't know why it doesn't converge with 1e-06.Konyaro
Hello Konyaro,
Thank you for help. And also i don't understand why?
I compared the result with theorical result and the analysis result is very close to theorical result. I think that 1e-5 didn't effect badly to the analysis result.
Samet
