#1 2017-12-17 00:50:04
Gerardova84
salome-meca for windows Error: Can not save file
Dear Sir,
eh installed salome-meca for windows, operating system windows 10 64 bits, I have the following error when trying to save:
Error is
Can not save file "/home/user/User/Gerardo/Desktop/study1.hdf"
possible reasons:
-permission denied;
-unsufficient disk space;
-application error.
I will appreciate your help.
Gerardo Rojas
#2 2017-12-18 17:14:10
Re: salome-meca for windows Error: Can not save file
This may sometimes happen with SALOME. Check that:
  • you're not using special characters or blanks in the path of the HDF study or the files used inside it;
  • you have enough free space left, notably in /tmp.
#3 2018-08-16 06:37:26
avee_10
i have 60 gb space in my disk but unable to save please help me out
#4 2019-04-14 21:01:48
brunodad
I cant save the files in windows neither.
I need help with this problem too.
Could someone tell us what is going on?
#5 2019-10-01 14:59:29
jango
Hello alltogether,
I'm facing the same problems in salome-meca 2018 for windows. There's enough diskspaceand I also checked the permissions. Is there any quick workaround to be able saving files ?
I would highly appreciate any quick help, as I'm using it very often in Liinux system, but I have windows on my portable computer.
Thank you,
Jan
#6 2019-11-07 14:20:36
henrique.moritz
I have been facing the exactly same problem as Gerardo, using Windows 10 64bits:
Can not save file "/(...).hdf"
possible reasons:
-permission denied;
-application error.
I noticed that this problem start happening when the simulation becomes bigger, requiring more disk space, however I have plenty of disk space!
Does anyone have a guess on how to solve this?
#7 2019-11-08 05:55:26
the problem is well known and explained in the post "Salome-Meca 2019 for Windows" in the site of Code_Aster for Windows. You must remove the "read only" flag of the files before saving them.
It is a Salome issue:
www salome-platform.org/forum/forum_10/520839533
#8 2019-11-08 13:39:48
henrique.moritz
The post on "Code Aster for Windows" website seems to cover a different kind of error...
Anyway, I tried to uncheck the "read only" flag from the file, but the error persists sad
#9 2019-11-20 10:32:39
highpressuretube
Have you unchecked the "read only" flag both on the hdf file and the _Files Folder and its contents?
#10 2020-04-23 08:53:23
highpressuretube
Have you found a solution? Because you were right, I have the same problem now, even when I uncheck read only.
#11 2020-05-29 13:16:59
stichko
Any news on this issue? Has the solution been posted somewhere else within this forum? Thanks anyway!
Serge
#12 2020-05-30 06:01:19
Have a look at:
www. salome-platform.org/forum/forum_10/541818275
#13 2020-06-02 13:14:07
stichko
Many thanks for the information. The proposed solution works smile !
#14 2020-07-28 12:18:08
kartikpandya
Dear Sir,
i have installed salome-meca for windows, operating system windows 10 64 bits, I have the following error when trying to save:
Error is
possible reasons:
-permission denied;
-application error.
#15 2020-07-28 18:43:57
tpa
Something to try:
Filename/path like "/home/user/User/Gerardo/Desktop/study1.hdf" is not a valid Windows path. Try another name.
Other reasons for not being able to write to the hdf file can be that a phantom server process is rendering the .hdf file R/O. In that case, save in a different name and afterwards shutdown the session server use the kill_salome.bat command (in the distribution directory).
