#1 2020-06-03 07:51:12
Prabhu
Von-Mises Stress in Salome-Meca
I want to find out the equivalent stress or von-misses stress in Salome.
In ansys i got a value of 443.93Mpa & In Salome i got a value of 462.789Mpa (Magnitude).
Comparing the Magnitude and Equivalent stress is correct or not?
I am using same model, same load, same constraints and same mesh, elements in both the models in Ansys & Salome.
Now i want to compare stress and deflection of them,
Result:
1. Deformation in the both cases are same.
2. Now how to compare and validate the Equivalent stress.
I attached the image file below for your reference.
Can anyone help me to find out the solution for this.
Thanks,
Prabhu M
#2 2020-06-20 05:10:36
Re: Von-Mises Stress in Salome-Meca
you can simply calculate them after your analysis:
resu1 = CALC_CHAMP(reuse=resu1,
                    CRITERES=('SIEQ_NOEU'),
                    RESULTAT=resu1,
                    TOUT_ORDRE='OUI')
and you will be able to display the Von Mises stresses called VMIS.
