#1 2020-08-13 07:38:00
marco.mueller
Usage of DYNA_NON_LINE for EN 62262 test
I'd like to use the dynamic solver to simulate the EN 62262 test, to get basic knowledge about the (plastic) deformation of our parts:
Is there a general objection regarding this? (I'm aware of the fact that implicit methods are not very well suited regarding calculation efficiency)
In my test model I face the issue that the initial velocity moves the impact body into the wrong direction and with a velocity differing from the one I applied. It's quite silly, but I can't find the reason why. Can somebody help me out?
A final question: Can I model the thin body with 2D elements (COQUE3D preferred) in this constellation? I tried to, but found that the boundary conditions were not properly applied.
Marco
Here my comm-file, the whole Salome Meca case is attached:
Netz1 = LIRE_MAILLAGE(FORMAT='MED',
                      UNITE=20)
Netz2 = LIRE_MAILLAGE(FORMAT='MED',
                      UNITE=2)
NetzL = ASSE_MAILLAGE(MAILLAGE_1=Netz1,
                      MAILLAGE_2=Netz2,
                      OPERATION='SUPERPOSE')
NetzQ = CREA_MAILLAGE(LINE_QUAD=_F(TOUT='OUI'),
                      MAILLAGE=NetzL)
FEModell = AFFE_MODELE(AFFE=_F(MODELISATION=('3D', ),
                               TOUT='OUI'),
                       MAILLAGE=NetzQ)
Kugelmat = DEFI_MATERIAU(ELAS=_F(E=210000.0,
                                 NU=0.316,
                                 RHO=1.91e-08))
Matdef = AFFE_MATERIAU(AFFE=_F(MATER=(Kugelmat, ),
                               TOUT='OUI'),
                       MODELE=FEModell)
Zeiten = DEFI_LIST_REEL(DEBUT=0.0,
                        INTERVALLE=_F(JUSQU_A=0.04,
                                      NOMBRE=20))
ZeitenI = DEFI_LIST_INST(DEFI_LIST=_F(LIST_INST=Zeiten),
                         METHODE='AUTO')
RB = AFFE_CHAR_MECA(DDL_IMPO=(_F(DX=0.0,
                                 DY=0.0,
                                 DZ=0.0,
                                 GROUP_NO=('Objekt_Fix', )),
                              _F(DX=0.0,
                                 GROUP_NO=('Objekt_SymX', 'Kugel_SymX')),
                              _F(DY=0.0,
                                 GROUP_NO=('Objekt_SymY', 'Kugel_SymY'))),
                    MODELE=FEModell)
Kontakt = DEFI_CONTACT(FORMULATION='DISCRETE',
                       MODELE=FEModell,
                       ZONE=_F(ALGO_CONT='PENALISATION',
                               E_N=2100.0,
                               GROUP_MA_ESCL=('Kugel_Kontakt', ),
                               GROUP_MA_MAIT=('Objekt_Kontakt', )))
IniVel = CREA_CHAMP(AFFE=_F(GROUP_NO=('Kugel', ),
                            NOM_CMP=('DX', 'DY', 'DZ'),
                            VALE=(0.0, 0.0, 2801.0)),
                    MODELE=FEModell,
                    OPERATION='AFFE',
                    TYPE_CHAM='NOEU_DEPL_R')
NLinDyn = DYNA_NON_LINE(CHAM_MATER=Matdef,
                        CONTACT=Kontakt,
                        ETAT_INIT=_F(VITE=IniVel),
                        EXCIT=_F(CHARGE=RB),
                        INCREMENT=_F(LIST_INST=ZeitenI),
                        MODELE=FEModell,
                        SCHEMA_TEMPS=_F(FORMULATION='DEPLACEMENT',
                                        SCHEMA='HHT'))
Proj = PROJ_CHAMP(MAILLAGE_2=NetzL,
                  MODELE_1=FEModell,
                  RESULTAT=NLinDyn)
Sig1 = CALC_CHAMP(CONTRAINTE=('SIGM_ELNO', ),
                  FORCE=('REAC_NODA', ),
                  RESULTAT=NLinDyn)
Sig3 = CALC_CHAMP(CONTRAINTE=('SIGM_NOEU', ),
                  CRITERES=('SIEQ_ELNO', 'SIEQ_NOEU'),
                  RESULTAT=NLinDyn)
Reak = POST_RELEVE_T(ACTION=_F(GROUP_NO=('Objekt_Fix', ),
                               INTITULE='Reaktionskraft',
                               NOM_CHAM='REAC_NODA',
                               OPERATION=('EXTRACTION', ),
                               RESULTANTE=('DX', 'DY', 'DZ'),
                               RESULTAT=Sig1))
IMPR_RESU(FORMAT='MED',
          RESU=(_F(NOM_CHAM=('DEPL', ),
                   NOM_CHAM_MED=('Verschiebungen', ),
                   RESULTAT=Proj),
                _F(NOM_CHAM=('SIEQ_ELNO', ),
                   NOM_CHAM_MED=('Spannungen', ),
                   RESULTAT=Sig3)),
          UNITE=80)
IMPR_TABLE(TABLE=Reak,
           UNITE=8)
#2 2020-08-13 16:09:18
Re: Usage of DYNA_NON_LINE for EN 62262 test
                                 NU=0.316,
                                 RHO=1.91e-08))
i have not seen your zip file, but you need to provide more details on material behaviour. for e.g strain vs strain data table for your kind of plastic
#3 2020-08-14 09:09:13
marco.mueller
I first wanted to make sure to get the dynamics running, so I did not care about the material so far - instead of choosing a density that leads to an impact body mass of 5 kg, according to the test.
In the end it would be sufficient to have a bilinear material for the test object with a simple stiffening model.
#4 2020-08-24 08:48:29
marco.mueller
I've found the issue: It was related to the CREA_MAILLAGE(LINE_QUAD) operation. Now, I provide a quadratic mesh and the dynamics work, also the whole case runs fine (with 3D meshing).
Coming back to my initial post: Is there a way to use 2D elements in conjunction with DYNA_NON_LINE and great deformations? I've found that COQUE_3D is not supported for that. I've also read in some thread 2 months ago, that a new (universal?) 2D element formulation is on the way ... Can anyone provide more details about that?
Marco
