#1 2020-09-04 04:31:15
cwf007
Non Convergence from shell to shell contact
Good day all,
Im having a problem with the convergence of contact by using shell element (COQUE 3D), It always diverge at 45% load.
Ive tried penalization method, but the result are much worst (failed at 1%)
Please feel free to comment and correct me.
Attached are the comm file and med file.
Thank you very much.
Warmest Regards,
cwf007.
#2 2020-09-07 15:44:17
Re: Non Convergence from shell to shell contact
I was curious to investigate your problem, I ran your files. The problem is: it already stops at AFFE_CHAR_MECA. So it does not reflect what you describe.
As your problem might be mesh related, could you upload your .hdf?
Thank you,
P.S.: your mesh file does not have the groups addressed in AFFE_CHAR_MECA, that's what the error says.
#3 2020-09-08 02:29:00
cwf007
Hi Mario,
Really appreciate your time.
Attached is the .hdf.
Thank you.
Warmest Regards,
cwf007.
#4 2020-09-08 07:05:20
I'm not used to shell elements but re-orienting the contact surfaces leads to convergence. I also modified the contact in order to make it faster.
#5 2020-09-08 10:48:20
cwf007
Hi Konyaro,
Thanks for helping out!!
Such a huge mistakes I've made!
May i know how do we really define the E_N on penalisation?
Thank you!
Warmest Regards,
cwf007.
#6 2020-09-22 03:25:57
cwf007
Dear all,
After switching to a slightly complex geometry, (denter and a panel) with VMIS_ISO_TRAC , Im getting non convergence at 30%
Feel free to comment on my model.
Attached is the hdf file.
Thank you smile
Warmest Regards,
cwf007
#7 2020-09-22 03:29:03
cwf007
Reattached the hdf file.
TQVM smile
#8 2020-09-23 08:49:23
marco.mueller
For my shell models, I've had quite good results with ALGO_CONT='PENALISATION' - also regarding run times!
If it fails, try to decrease E_N (For steel-steel, I've used Young's Modulus/100).
E_N may be too low, if you get contact penetration.
#9 2020-09-24 02:08:40
cwf007
Hi Marco,
Definitely will try to reduce E_N
Thanks for the tips!
Warmest Regards,
cwf007.
