#1 2020-09-10 13:20:16
code_aster 14.4 parallel version with PETSc - Mumps error & further he
Mumps installation while compiling MPI version with Petsc has below error, Can Anybody pointout where i am might be going wrong. i am following  hitoricae.com/2019/11/10/code_aster-14-4-with-petsc/  link
$ make all
make ARITH=c mumps_lib
make[1]: Entering directory '/home/sameer/Install_Files/opt/mumps-5.1.2_mob'
(cd src ; make c)
make[2]: Entering directory '/home/sameer/Install_Files/opt/mumps-5.1.2_mob/src'
make[3]: Entering directory '/home/sameer/Install_Files/opt/mumps-5.1.2_mob/src'
mpif90 -O -fPIC -DPORD_INTSIZE64 -fopenmp -I/opt/aster/public/metis-5.1.0/include -I/opt/parmetis-4.0.3/include -I/opt/scotch-6.0.4/include -I/opt/aster/public/metis-5.1.0/include -I/opt/parmetis-4.0.3/include -I/opt/scotch-6.0.4/include -Dpord -Dmetis -Dparmetis -Dscotch -Dptscotch -I. -I../include -c ana_orderings_wrappers_m.F -o ana_orderings_wrappers_m.o
f951: Warning: Nonexistent include directory ‘/opt/scotch-6.0.4/include’ [-Wmissing-include-dirs]
ana_orderings_wrappers_m.F:371: Error: Can't open included file 'scotchf.h'
Makefile:293: recipe for target 'ana_orderings_wrappers_m.o' failed
make[3]: *** [ana_orderings_wrappers_m.o] Error 1
make[3]: Leaving directory '/home/sameer/Install_Files/opt/mumps-5.1.2_mob/src'
Makefile:20: recipe for target 'c' failed
make[2]: *** [c] Error 2
make[2]: Leaving directory '/home/sameer/Install_Files/opt/mumps-5.1.2_mob/src'
Makefile:40: recipe for target 'mumps_lib' failed
make[1]: *** [mumps_lib] Error 2
make[1]: Leaving directory '/home/sameer/Install_Files/opt/mumps-5.1.2_mob'
Makefile:18: recipe for target 'c' failed
make: *** [c] Error 2
#2 2020-09-10 22:16:02
Irvise
Re: code_aster 14.4 parallel version with PETSc - Mumps error & further he
Here is the key of your error:
The scotch directory the build is referencing does not exist.
I have given the guide a quick look. The scoth build is just right before the mups one. Make sure that you have done the scotch build successfully and that the /opt/scotch-6.0.4/include exist.
Fer
#3 2020-09-11 07:34:13
scotch 6.0.4 already build in Install_Files/opt/
have install files as under. hope, steps also point out what i have done wrong.
make folder - Install_Files
mkdir opt in above folder
In Install_Files Folder following files where Extract & install as per procedure set
a. OpenBlas 3.10
b. aster_full src 14.4.0
c. parmetis 4.03
d. scalapack_installer
Now, in Folder
Install_Files/opt
following files were extracted and install as per procedure set
a. scotch6.0.4 ( copied .gz file from aster full 14.04 )
b. mumps 5.1.2_mob ( name changed ) ( coped .gz file from aster full 14.04)
while installing mumps above error shown.
kindly reply any step of installation missing out.
#4 2020-09-12 19:29:53
Irvise
Hi.
The compile line:
Is looking for files under the \opt directory. This directory is absolute, meaning it is the \opt directory that lives under \. The "\opt" directory you are referring to is a local (or better said, relative) directory that lives under "/home/sameer/Install_Files/opt".
The quickest and easiest way to fix this would be by redoing all the compilation under the expected directory: the \opt directory. There may be a way to indicate the make command to use a different directory to look for the libraries, but that would require manual intervention. I am not saying this would be a difficult thing to do, but it will require quite a bit more debugging since it will most likely not work on the first try.
Fer
#5 2020-09-14 12:17:51
Ok. Have started installing with your given instructions but got stuck with petsc-3.9.4.tar.gz...installing hypre.
github path to installation Hypre doesnot exist.
./configure --with-debugging=0 COPTFLAGS=-O CXXOPTFLAGS=-O FOPTFLAGS=-O --with-shared-libraries=0 --with-scalapack-dir=/opt/scalapack-n --PETSC_ARCH=linux-metis-mumps --with-metis-dir=/opt/aster/public/metis-5.1.0 --with-parmetis-dir=/opt/parmetis-4.0.3 --with-ptscotch-dir=/opt/scotch-6.0.4 --LIBS="-lgomp" --with-mumps-dir=/opt/mumps-5.1.2_mob -with-x=0 --with-blas-lapack-lib=[/opt/OpenBLAS/lib/libopenblas.a] --download-hypre=yes --download-ml=yes
on repeating above command below config.log file shows details
#6 2020-09-14 12:37:47
check below attach file
#7 2020-09-14 12:53:11
#endif
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Unable to run git stash/clean in repository: /opt/petsc-3.9.4/linux-metis-mumps/externalpackages/git.ml.
Perhaps its a git error!
  File "./config/configure.py", line 394, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/opt/petsc-3.9.4/config/BuildSystem/config/framework.py", line 1092, in configure
    self.processChildren()
  File "/opt/petsc-3.9.4/config/BuildSystem/config/framework.py", line 1081, in processChildren
    self.serialEvaluation(self.childGraph)
  File "/opt/petsc-3.9.4/config/BuildSystem/config/framework.py", line 1062, in serialEvaluation
    child.configure()
  File "/opt/petsc-3.9.4/config/BuildSystem/config/package.py", line 864, in configure
    self.executeTest(self.configureLibrary)
  File "/opt/petsc-3.9.4/config/BuildSystem/config/base.py", line 127, in executeTest
    ret = test(*args,**kargs)
  File "/opt/petsc-3.9.4/config/BuildSystem/config/package.py", line 753, in configureLibrary
    for location, directory, lib, incl in self.generateGuesses():
  File "/opt/petsc-3.9.4/config/BuildSystem/config/package.py", line 355, in generateGuesses
    d = self.checkDownload()
  File "/opt/petsc-3.9.4/config/BuildSystem/config/package.py", line 481, in checkDownload
    return self.getInstallDir()
  File "/opt/petsc-3.9.4/config/BuildSystem/config/package.py", line 294, in getInstallDir
    self.updateGitDir()
  File "/opt/petsc-3.9.4/config/BuildSystem/config/package.py", line 574, in updateGitDir
    raise RuntimeError('Unable to run git stash/clean in repository: '+self.packageDir+'.\nPerhaps its a git error!')
Finishing configure run at Mon, 14 Sep 2020 16:56:34 +0530
#8 2020-09-16 08:04:27
Running make install on ML; this may take several minutes                                                               ===============================================================================                                               **************************************************************************************************                            Please register to use hypre at computation.llnl.gov/casc/linear_solvers/sls_hypre.html                               **************************************************************************************************                            ===============================================================================                                                     Trying to download git:// github.com/LLNL/hypre for HYPRE
github.com/LLNL/hypre/archive/v2.14.0.tar.gz is not a tarball
github has removed above link
where to download hypre manually and rerun terminal command
#9 2020-09-16 15:06:07
hypre manually added...
but have further problem
asrun not read...error as under.
Checking measure of VmSize during MPI_Init : ok
Checking for library pthread             : yes
Checking for library dl                  : yes
Checking for library util                : yes
Checking for program 'python'            : /usr/bin/python3
Checking for python version >= 3.5.0     : 3.6.9
python-config                            : /usr/bin/python3-config
Asking python-config for pyembed '--cflags --libs --ldflags' flags : yes
Testing pyembed configuration            : yes
Asking python-config for pyext '--cflags --libs --ldflags' flags : yes
Testing pyext configuration              : yes
Checking for numpy                       : /home/sameer/.local/lib/python3.6/site-packages/numpy/__init__.py
Checking for numpy version               : 1.19.2
Checking for numpy include               : ['/home/sameer/.local/lib/python3.6/site-packages/numpy/core/include']
Checking for asrun                       : Could not find the python module 'asrun'
(complete log in /home/sameer/Install_Files/aster-full-src-14.4.0/SRC/aster-14.4.0/build/std/config.log)
#include <Python.h>
#include <numpy/arrayobject.h>
int main(int argc, char **argv) {
    (void)argc; (void)argv;
    return 0;
[1/2] Compiling [32mbuild/std/.conf_check_d1e8da006504a519a3971608c01ca992/test.cpp[0m
['mpicxx', '-g', '-fdebug-prefix-map=/build/python3.6-npOuKa/python3.6-3.6.9=.', '-fstack-protector', '-g', '-fwrapv', '-O3', '-I../../../../../../../../../.local/lib/python3.6/site-packages/numpy/core/include', '-I/opt/petsc-3.9.4/linux-metis-mumps/include', '-I/opt/petsc-3.9.4/include', '-I/ usr / include / superlu', '-I/opt/parmetis-4.0.3/include', '-I/opt/mumps-5.1.2_mob/include', '-I/opt/aster/public/hdf5-1.10.3/include', '-I/opt/aster/public/med-4.0.0/include', '-I/opt/aster/public/metis-5.1.0/include', '-I/opt/scotch-6.0.4/include', '-I/opt/scalapack-n/include', '-I/opt/OpenBLAS/include', '-I/usr/include/python3.6m', '-DHAVE_MPI=1', '-D_USE_MPI=1', '-D_USE_OPENMP=1', '-DENABLE_PROC_STATUS=1', '-DPYTHONDIR="/opt/aster/PAR14.4MUPT/lib/python3.6/site-packages"', '-DPYTHONARCHDIR="/opt/aster/PAR14.4MUPT/lib/python3.6/site-packages"', '-DHAVE_PYEMBED=1', '-DHAVE_PYEXT=1', '-DNPY_NO_PREFIX', '-DNDEBUG', '../../test.cpp', '-c', '-o/home/sameer/Install_Files/aster-full-src-14.4.0/SRC/aster-14.4.0/build/std/.conf_check_d1e8da006504a519a3971608c01ca992/testbuild/release/test.cpp.1.o']
err: In file included from ../../../../../../../../../.local/lib/python3.6/site-packages/numpy/core/include/numpy/ndarraytypes.h:1822:0,
                 from ../../../../../../../../../.local/lib/python3.6/site-packages/numpy/core/include/numpy/ndarrayobject.h:12,
                 from ../../../../../../../../../.local/lib/python3.6/site-packages/numpy/core/include/numpy/arrayobject.h:4,
                 from ../../test.cpp:2:
../../../../../../../../../.local/lib/python3.6/site-packages/numpy/core/include/numpy/npy_1_7_deprecated_api.h:17:2: warning: #warning "Using deprecated NumPy API, disable it with " "#define NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION" [-Wcpp]
#warning "Using deprecated NumPy API, disable it with " \
[2/2] Linking [33mbuild/std/.conf_check_d1e8da006504a519a3971608c01ca992/testbuild/release/testprog[0m
['mpicxx', '-Xlinker', '-export-dynamic', '-Wl,-O1', '-Wl,-Bsymbolic-functions', 'test.cpp.1.o', '-o/home/sameer/Install_Files/aster-full-src-14.4.0/SRC/aster-14.4.0/build/std/.conf_check_d1e8da006504a519a3971608c01ca992/testbuild/release/testprog', '-Wl,-Bstatic', '-Wl,-Bdynamic', '-L/opt/petsc-3.9.4/linux-metis-mumps/lib', '-L/opt/parmetis-4.0.3/lib', '-L/opt/mumps-5.1.2_mob/lib', '-L/opt/aster/public/hdf5-1.10.3/lib', '-L/opt/aster/public/med-4.0.0/lib', '-L/opt/aster/public/metis-5.1.0/lib', '-L/opt/scotch-6.0.4/lib', '-L/opt/scalapack-n/lib', '-L/opt/OpenBLAS/lib', '-L/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu', '-L/usr/lib', '-lX11', '-lpthread', '-ldl', '-lutil', '-lpython3.6m', '-lpthread', '-ldl', '-lutil', '-lm', '-lpython3.6m', '-lpthread', '-ldl', '-lutil', '-lm']
Checking for asrun
['/usr/bin/python3', '-c', "\nimport asrun as current_module\nversion = getattr(current_module, '__version__', None)\nif version is not None:\n\tprint(str(version))\nelse:\n\tprint('unknown version')\n"]
err: Traceback (most recent call last):
  File "<string>", line 2, in <module>
ModuleNotFoundError: No module named 'asrun'
from /home/sameer/Install_Files/aster-full-src-14.4.0/SRC/aster-14.4.0: Could not find the python module 'asrun'
#10 2020-09-16 22:04:45
Irvise
Hi.
Could you post the contents of this file? (complete log in /home/sameer/Install_Files/aster-full-src-14.4.0/SRC/aster-14.4.0/build/std/config.log) The issue seems to be that it cannot find the python module/file known as asrun.
On another note, Hypre has changed its github, right now it is github.com/hypre-space/hypre the build scripts will need to be updated. However, I do not know who is responsible in this case.
Fer
#11 2020-09-17 07:15:06
kindly refer attach log file.
#12 2020-09-18 07:29:39
waiting for reply.
Request CA Developers to include Petsc as available in standard Download of CA new version. Contact problems require Petsc.
#13 2020-09-20 18:48:29
Irvise
Hi Sameer,
after taking a look at the complete .log, my conclusion is the same. CA has a python module known as "asrun". During the build process, a few checks are done to make sure that all the dependencies are met before compiling CA. This is where it is failing, the system is unable to find the python module "asrun".
I am not very well versed with the python module system and how it works. I suppose that the "asrun" module is present somewhere the CA source folder. However, the python interpreter of your system "/usr/bin/python3" is not able to find it. My best guess is that the build script  is not exporting the PATH where "asrun" is present and therefore, the system fails to import it.
I am sadly unable to help you any further. Regards,
Fernando
#14 2020-09-21 07:15:33
Hello Fernando,
Yes you are right asrun is folder and it do exist in /opt/aster/lib/python3.6/site-packages/asrun
exportPath is not reading in my computer.
I Tried to Install CA Parallel on my Laptop, It Accepted asrun but AS HYPRE  IS INSTALLED MANUALLY the last step $ ./waf install -p --jobs=1 FAILED to Install and it has All Hypre Errors.
So, Some Expert from CA can Fix the Original Script with New Hypre Installation Address.
#15 2020-09-24 09:25:06
linctus
For asrun module not found issue, you have to set environment variables before ./waf configure
export ASTER_ROOT=where you install aster
export PYTHONPATH=$ASTER_ROOT/lib/python3.6/site-packages:$PYTHONPATH
./waf configure ....
For Hypre issue, you can try to compile petsc again letting it download hypre thing rather than MANUAL installation.
What you need to do is to modify the hypre repository in this file:
petsc-3.9.4/config/BuildSystem/config/packages/hypre.py
In this file, change
self.download  = ['git://https://github.com/LLNL/hypre','https://github.com/LLNL/hypre/archive/'+self.gitcommit+'.tar.gz']
to
self.download  = ['git://https://github.com/hypre-space/hypre','https://github.com/hypre-space/hypre/archive/'+self.gitcommit+'.tar.gz']
Hope this helps.
#16 2020-09-25 07:49:04
Thanks for your input.
The Hypre, Now is getting Download.
asrun environment reading is still problem on my computer though path is correct.
#17 2020-09-27 04:46:16
linctus
How exactly did you set the PYTHONPATH variable? Can you list the python paths by
echo $PYTHONPATH
then check if /opt/aster/lib/python3.6/site-packages is listed in the output?
If not, then the variable was not set correctly.
If you are sure asrun module is in /opt/aster/lib/python3.6/site-packages
then the correct way to set it is
export ASTER_ROOT=/opt/aster
I notice that there is a typo in the hitoricae page you refer to:
export PYTHONPATH=/$ASTER_ROOT/lib/python3.6/site-packages/:$PYTHONPATH
please note that there is a '/' before '$ASTER_ROOT' which could be the cause of your problem.
By the way from your config.log file I notice another error about the include directory of superlu:
err: f951: Warning: Nonexistent include directory ‘/ usr / include / superlu’ [-Wmissing-include-dirs]
there are several space in the path which should not be there.
Good luck.
#18 2020-09-28 14:27:31
thanks for you input.
i need to be software expert to install parallel version.
now, asrun is working,,,,error shows .med is not install.
i again done aster installation from start....below attached log file shows error.
#19 2020-09-29 05:33:36
linctus
It looks like MED-4.0.0 failed in configure stage. But the setup.log file doesn't give so much information about that (that's why it says 'See `config.log' for more details').
Does '/tmp/install_med.23914/med-4.0.0' directory still there? There should be a config.log file in that directory which probably has more detail of the error.
#20 2020-09-29 08:50:23
/tmp/install_med.4515/med-4.0.0
config.log file at above location.
refer attachment
#21 2020-09-29 08:53:09
/tmp/install_aster.4515/aster-14.4.0/build/std/config.log
config fil at above location.
refer attachment
#22 2020-09-30 09:05:06
linctus
The congigure failed when it tried to link to some libraries which could not be found. There are several similar errors, but the first instance appears in line 463-466
/usr/bin/ld: cannot find /usr/libx32/libm-2.27.a
/usr/bin/ld: skipping incompatible /usr/libx32/libmvec.a when searching for /usr/libx32/libmvec.a
/usr/bin/ld: cannot find /usr/libx32/libmvec.a
collect2: error: ld returned 1 exit status
Now trace back to line 455, the configure command is
configure:8799: /usr/bin/gcc -o conftest -O2 -fno-stack-protector -fPIC  -Wl,--no-as-needed -L/usr/libx32 -lpthread -L/usr/lib/x86_64-linux-gnu -lz -L/usr/lib/gcc/x86_64-linux-gnu/7 -lstdc++ conftest.c   -L/usr/libx32 -L/usr/lib/x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/7 -L/usr/lib/gcc/x86_64-linux-gnu/7/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/7/../../..      -lpthread -lz -lstdc++ -lgfortran -lm -lquadmath /usr/libx32/libpthread.a /usr/libx32/libm.a /usr/libx32/libc.a >&5
in the last part the configure command tells to link to /usr/libx32/libpthread.a /usr/libx32/libm.a /usr/libx32/libc.a
Now trace back to line 453
configure:8749: result:  -L/usr/libx32 -L/usr/lib/x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/7 -L/usr/lib/gcc/x86_64-linux-gnu/7/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/..     /lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/7/../../.. -lpthread -lz -lstdc++ -lgfortran -lm -lquadmath /usr/libx32/libpthread.a /usr/libx32/libm.a /usr/libx32/libc.a
I think this the problem. Why configure tried to link to these /usr/libx32/lib* libraries? You are using a x86_64 Ubuntu so it should look like
configure:8749: result:  -L/usr/lib/x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/7 -L/usr/lib/gcc/x86_64-linux-gnu/7/../../../x86_64-linu     x-gnu -L/usr/lib/gcc/x86_64-linux-gnu/7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-g     nu/7/../../.. -lpthread -lz -lstdc++ -lgfortran -lm -lquadmath
You didn't have this problem when you started this post right? So I am totally lost. My guess is that the environment was messed up. Maybe the easest way is to delete everything you have done, exit current bash (logout and login again, or just reboot) and start it over from the first beginning (extract aster-full-src-14.4.0-1.noarch.tar.gz to get a fresh source code directory).
Good luck.
#23 2020-09-30 14:31:14
.med file was not getting read from beginning but i thought, let's move further & understand where other problems are comming.
any changes can be made or i can delete some additional software packages on ubuntu to stop this error
#24 2020-10-01 04:33:06
linctus
OK I understand.
From setup.log.2 line 45, 47-49,
Checking for libpthread.so... /usr/libx32/libpthread.so
Checking for libz.so... /usr/lib/x86_64-linux-gnu/libz.so
Checking for libdl.so... /usr/libx32/libdl.so
Checking for libutil.so... /usr/libx32/libutil.so
Checking for libm.so... /usr/libx32/libm.so
some libc libraries were found in /usr/libx32. Those files belongs to package libc6-dev-x32. Do you have this package installed and did you install this package for some specific reason?
(1)If it's safe to remove this package, you can remove it and try again. (But be sure package libc6-dev is still installed).
(2)If it's impossible to remove this package for some reason, you have to tell aster setup to find libc libraries (libpthread.so, libdl.so, libm.so, etc) in /usr/lib/x86_64-linux-gnu rather than in /usr/libx32. But I don't how to do that yet. (I am not even sure if it's possible).
#25 2020-10-01 14:01:13
thanks for your prompt reply.
removed libc6-dev-x32
then again run CA
med install
but
Installation of   : aster 14.4.0
Destination       : /opt/aster
Elapsed time      : 774.72 s
*** Exception None raised : None
See detailed traceback in the logfile
        [FAILED]
log file attached herewith.
Waf: Leaving directory `/tmp/install_aster.11869/aster-14.4.0/build/std/release'
+ build the elements catalog elem.1 using installed aster (from /tmp/install_aster.11869/aster-14.4.0/build/std/release/catalo/cata_ele.ojb)
stdout:
stderr: Segmentation fault (core dumped)
To run manually, use:
BINDIR="/opt/aster/14.4/bin"
LIBDIR="/opt/aster/14.4/lib"
PYTHONDIR="/opt/aster/14.4/lib/python3.6/site-packages"
export LD_LIBRARY_PATH="/opt/aster/public/hdf5-1.10.3/lib:/opt/aster/public/med-4.0.0/lib:/opt/aster/public/mumps-5.1.2/lib:/opt/aster/public/metis-5.1.0/lib:/opt/aster/public/tfel-3.2.1/lib:/opt/aster/public/scotch-6.0.4/lib:/opt/aster/public/hdf5-1.10.3/lib64:/opt/aster/public/med-4.0.0/lib64:/opt/aster/14.4/lib:/opt/aster/14.4/lib/aster:/home/sameer/Install_Files/aster-full-src-14.4.0:/usr:/usr/lib/gcc/x86_64-linux-gnu/7:/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/opt/aster/public/tfel-3.2.1/lib:/opt/aster/public/tfel-3.2.1"
export PYTHONPATH="/opt/aster/14.4/lib/aster:/home/sameer/Install_Files/aster-full-src-14.4.0:/opt/aster/lib/python3.6/site-packages:/opt/aster/public/tfel-3.2.1/lib/python3.6/site-packages"
${BINDIR}/aster /opt/aster/14.4/lib/aster/Execution/E_SUPERV.py -commandes /tmp/install_aster.11869/aster-14.4.0/build/std/release/fort.1 -memjeveux 500 -tpmax 120
Command 'LD_LIBRARY_PATH="/opt/aster/public/hdf5-1.10.3/lib:/opt/aster/public/med-4.0.0/lib:/opt/aster/public/mumps-5.1.2/lib:/opt/aster/public/metis-5.1.0/lib:/opt/aster/public/tfel-3.2.1/lib:/opt/aster/public/scotch-6.0.4/lib:/opt/aster/public/hdf5-1.10.3/lib64:/opt/aster/public/med-4.0.0/lib64:/opt/aster/14.4/lib:/opt/aster/14.4/lib/aster:/home/sameer/Install_Files/aster-full-src-14.4.0:/usr:/usr/lib/gcc/x86_64-linux-gnu/7:/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/opt/aster/public/tfel-3.2.1/lib:/opt/aster/public/tfel-3.2.1" ${BINDIR}/aster /opt/aster/14.4/lib/aster/Execution/E_SUPERV.py -commandes /tmp/install_aster.11869/aster-14.4.0/build/std/release/fort.1 -memjeveux 500 -tpmax 120' returned 139
EXIT_COMMAND_11869_00000106=1
*** Exception raised : error during installation
     SUMMARY OF INSTALLATION
Installation of   : hdf5 1.10.3
Destination       : /opt/aster/public/hdf5-1.10.3
Elapsed time      : 309.33 s
        [  OK  ]
Installation of   : med 4.0.0
Destination       : /opt/aster/public/med-4.0.0
Elapsed time      : 253.32 s
        [  OK  ]
Installation of   : gmsh 3.0.6
Destination       : /opt/aster/public/gmsh-3.0.6-Linux
Elapsed time      : 1.14 s
        [  OK  ]
Installation of   : scotch 6.0.4
Destination       : /opt/aster/public/scotch-6.0.4
Elapsed time      : 40.96 s
        [  OK  ]
Installation of   : astk 2019.0
Destination       : /opt/aster/lib/python3.6/site-packages
Elapsed time      : 1.01 s
        [  OK  ]
Installation of   : metis 5.1.0
Destination       : /opt/aster/public/metis-5.1.0
Elapsed time      : 30.50 s
        [  OK  ]
Installation of   : tfel 3.2.1
Destination       : /opt/aster/public/tfel-3.2.1
Elapsed time      : 789.70 s
        [  OK  ]
Installation of   : mumps 5.1.2
Destination       : /opt/aster/public/mumps-5.1.2
Elapsed time      : 149.88 s
        [  OK  ]
Installation of   : homard 11.12
Destination       : /opt/aster/public/homard-11.12
Elapsed time      : 4.72 s
        [  OK  ]
        [FAILED]
Exit code : 4
Installation of   : Code_Aster + 10 of its prerequisites
Elapsed time      : 2598.24 s
        [  OK  ]
