#26 2020-08-05 23:25:27
Re: Installation on Ubuntu 20.04
From the output you have shown viz.
./create_appli.sh: line 263: python: command not found
it appears that there is still python name error.
1. Please make sure that you followed the step no 4 and 6 described in my post.
2. Following all the steps serially is important.
3. Only this much I can say now, based on your report.
Hope this helps.
Please let us know here, whether this works or not.
Regards.
#27 2020-08-29 10:07:07
Hems
Hi Sukumar,
Thanks a lot. I followed the procedure again as per your suggestion. It worked!
But I have same message as Roger has about the Europlexus module. I decided to ignore it for now.
Thanks and regards,
Hems
#28 2020-09-18 19:03:15
amvali
Hi there,
I followed instruction and install Salome-Meca, but still having problem with installation. Here what I got after installation:
amvali@amvali-VirtualBox:~$ ./salome_meca-2019.0.3-1-universal.run
Self Extracting salome_meca V2019.0.3_universal Installer
Enter the salome_meca install directory [default=/home/amvali/salome_meca] : salome_meca is in English, do you want to be in French ? [y/N] : n
Installation of salome_meca V2019.0.3_universal in /home/amvali/salome_meca/V2019.0.3_universal ...
All good.
Done
Creating salome_meca application in /home/amvali/salome_meca/appli_V2019.0.3_universal ...
To run the application:
$ /home/amvali/salome_meca/appli_V2019.0.3_universal/salome
Adjusting wishexecutable /home/amvali/salome_meca/V2019.0.3_universal/tools/Code_aster_frontend-20190/etc/codeaster/profile.sh
Final configuration
Would you please help me?
Thanks,
Ali
