#26 2020-10-12 10:04:49
Clement M
Re: How to increase the speed
Ok thank you
#27 2020-10-12 12:26:25
mib
Hi
good news :
YES is possible to "concatenate" med file of stage 1 with med file of stage 2. imposeign how start coditions of stage 2 the final conditions of stage 1.
resnonla = DYNA_NON_LINE(CHAM_MATER=fieldmat,
                         COMPORTEMENT=_F(DEFORMATION='SIMO_MIEHE',
                                         RELATION='VMIS_ISOT_LINE'),
                         CONVERGENCE=_F(ITER_GLOB_MAXI=30),
>>>>>>>>>> ETAT_INIT=_F(EVOL_NOLI=resnonl),<<<<<<<<<<<<<<<<<<<<<
                         EXCIT=_F(CHARGE=rotaa),
                         INCREMENT=_F(LIST_INST=timesa),
                         NEWTON=_F(MATRICE='TANGENTE',
                                   PREDICTION='TANGENTE'),
>>>>>>>>>>RESULTAT=resnonl,<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                         SCHEMA_TEMPS=_F(FORMULATION='DEPLACEMENT',
                                         SCHEMA='HHT'),
                         SOLVEUR=_F(METHODE='MUMPS'))
here the video :
youtube.com/watch?v=zfRPxac1sW0
(for my videos i used small values of acceleration velocity and time range, for a rapid computation)
#28 2020-10-13 09:52:26
mib
Clement M wrote:
Thanks a lot for your answers
Yes it is basicly what I want to do.
To explain you a bit better I am in intership and my goal is to simulate the expansion of a flywheel. Some experiments with the same flywheel at different speed were made and my aim is to be as close as possible from this results. But before working with this complex object I am simulating a simple cylinder with an hole, so a pipe, in two dimension.
It seems to work fine but I can t do a lot of revolution at high speed (my goal is 20 000 rpm) because I have convergence problem. So I need to have an extremely small timestep and I have problem with memory.
So to solve this problem and to be closer from the experiments I am trying to have a speed which goes from 0 to 20 000 rpm in few seconds and not directly 20 000 rpm during the whole simulation. As I didn t have the speed in my rotation formula I was trying to change an other parameter. I try with dtheta but as it wasn t a scalar anymore it wasn t recognized in the formula and it didn t work. So I don t really know what to do. I hope you will understand better my problem.
What you send me seems way better but I don t understand why cos(t) and how to define n(dt) in code aster.
Thanks again for your help I really appreciate it.
Formula 1 or MotoGP flywheel ???? :-D
#29 2020-10-13 11:29:05
share your flywheel mesh file.
#30 2020-10-14 11:11:42
mib
Only for Italian User
Troll o è davvero Clemente ???
napoli.repubblica.it/dettaglio/tangenti-bufera-su-mastella-in-un-file-la-lista-di-raccomandati/1755990/2
#31 2020-10-17 10:11:07
Clement M
Thanks for you time it is working fine. I can t share the flywheel mesh for confidentiality reason.
And I am not italien smile
