#1 2021-01-14 15:10:40
VonPire
Is it possible get SIEQ_ELNO and SIEG_ELGA from Coque_3D
I have a problem with Coque_3d post processing with Paravis.
I've read that there is two possible ways to print stresses in Paravis from COQUE_3D model:
1. Duplicate Quadratic (QUAD8 or TRIA6 elements) mesh with CREA_MAILLE before changing the mesh to QUAD9 or TRIA7. Then at IMPR_RESU requesting results for the copied quadratic mesh GROUP_MA.
2. Project results from QUAD9/TRIA7 model to QUAD8/TRIA6 model.
I've managed to get DEPL, SIGM_NOEU and SIEQ_NOEU visible in Paravis, but not SIEQ_ELNO, SIEQ_ELGA or SIGM_ELNO, SIGM_ELGA with the procedure number 2 (projecting):
resnonl = STAT_NON_LINE(identifier='14:1',
                        CARA_ELEM=elempro0,
                        CHAM_MATER=fieldmat,
                        COMPORTEMENT=_F(DEFORMATION='GROT_GDEP',
                                        RELATION='VMIS_ISOT_TRAC'),
                        CONVERGENCE=_F(ITER_GLOB_MAXI=100),
                        EXCIT=(_F(CHARGE=FIXL),
                               _F(CHARGE=load1,
                                  FONC_MULT=func)),
                        INCREMENT=_F(LIST_INST=times),
                        METHODE='NEWTON',
                        NEWTON=_F(MATRICE='TANGENTE',
                                  PREDICTION='TANGENTE',
                                  REAC_ITER=1))
proj0 = PROJ_CHAMP(identifier='15:1',
                   MODELE_1=model,
                   MODELE_2=model1,
                   RESULTAT=resnonl,
                   TOUT_CHAM='OUI',
                   TOUT_ORDRE='OUI')
resnonl = CALC_CHAMP(identifier='16:1',
                     reuse=resnonl,
                     CONTRAINTE=('SIGM_ELNO', ),
                     RESULTAT=resnonl,
                     TOUT_ORDRE='OUI')
ResINF = POST_CHAMP(identifier='17:1',
                    EXTR_COQUE=_F(NIVE_COUCHE='INF',
                                  NOM_CHAM=('SIGM_ELNO', 'SIEF_ELGA', 'SIEQ_ELNO'),
                                  NUME_COUCHE=1),
                    RESULTAT=resnonl,
                    TOUT_ORDRE='OUI')
ResINF = CALC_CHAMP(identifier='18:1',
                    reuse=ResINF,
                    CONTRAINTE=('SIGM_NOEU', 'SIGM_ELNO'),
                    CRITERES=('SIEQ_ELNO', 'SIEQ_NOEU'),
                    RESULTAT=ResINF,
                    TOUT_ORDRE='OUI')
projINF = PROJ_CHAMP(identifier='19:1',
                     MODELE_1=model,
                     MODELE_2=model1,
                     RESULTAT=ResINF,
                     TOUT_CHAM='OUI',
                     TOUT_ORDRE='OUI')
ResSup = POST_CHAMP(identifier='20:1',
                    EXTR_COQUE=_F(NIVE_COUCHE='SUP',
                                  NUME_COUCHE=1),
                    RESULTAT=resnonl)
ResSup = CALC_CHAMP(identifier='21:1',
                    reuse=ResSup,
                    RESULTAT=ResSup)
projSUP = PROJ_CHAMP(identifier='22:1',
                     MODELE_1=model,
                     MODELE_2=model1,
                     RESULTAT=ResSup,
                     TOUT_CHAM='OUI',
                     TOUT_ORDRE='OUI')
IMPR_RESU(identifier='23:1',
          FORMAT='MED',
          RESU=(_F(RESULTAT=projSUP,
                   TOUT_CHAM='OUI',
                   TOUT_ORDRE='OUI'),
                _F(RESULTAT=projINF,
                   TOUT_CHAM='OUI',
                   TOUT_ORDRE='OUI'),
                _F(RESULTAT=proj0,
                   TOUT_CHAM='OUI',
                   TOUT_ORDRE='OUI')),
          UNITE=80)
Are there anyone who had the same problem and managed to get it work ?
It is also a little bit unclear what TOUT_ORDRE does. Is this only for modal analysis ?
I have a simple test model for this where 2mm sheet metal is fixed from the bottom edge and load is applied to the upper edge. The .comm file is as attachment.
#2 2021-01-14 17:03:16
VonPire
Re: Is it possible get SIEQ_ELNO and SIEG_ELGA from Coque_3D
Here is also the .med file as attachment
