I'm working on a semicircular geometry and orthotropic material properties using shell DST elements. I need to set the reference direction for each element in the radial direction so that the main orthotropic direction is pointing radially. Is there a way of quickly doing this from the Salome interface?
I attached a picture of the geometry for clarity.
Thanks,
Massimo
