#1 2021-01-29 08:21:04
LIAISON_GROUP: Il y a un conflit dans les vis-à-vis des noeuds
I try to impose a cyclic condition on a compatible mesh with LIAISON_GROUP specifying ANGL_NAUT. I tried many different settings but always get the same error: "Il y a un conflit dans les vis-à-vis des noeuds [...]"
There is a similar post without solution:
https://code-aster.org/forum2/viewtopic.php?id=20628
Any hint welcome,
attached: MED, comm and mess files of a simple example.
