#1 2021-01-29 12:41:44
fraperrone18
Applying nodal displacements node by node
There are probably other threads similar to this, but I have not found analogous to my case.
What I would like to do is apply displacements to individual nodes inside a for loop in python. The displacements will depend on the coordinates of the node, so we need to access it.
We can resume the steps as follows:
- get a list of node IDs from a GROUP_NO
- loop trough for each node in the list
- get the coordinates of the node
- applies a displacement calculated using the node coordinate
This is what i should do in theory, does anyone know how to do it practically?
Thanks in advance!
#2 2021-01-29 15:18:04
GPSalachs
Re: Applying nodal displacements node by node
Well... I have an idea...But idk if it will work. Check out this post
/forum2/viewtopic.php?id=25327
so from the tip of my mind i would say, to extract the node coordinates and assign those to a "new" empty variable so like from X_Coord to X_Coord_EM then this variable be taken and with FORMULE command add or retract the wanted quantity (X_Coord_EM + or - the quantity) and re-assign said quantity again to the variable that will be read later as displacement assigned on the nodes on each iteration of the defined loop.
#3 2021-01-29 17:12:37
you can do it easily with AFFE_CHAR_MECA_F, for instance :
def FdispX(INST, X, Y):
    R = sqrt(X**2 + Y**2)
    x = X / R * 0.05 * INST
    return x
deplX=FORMULE(NOM_PARA=('INST','X','Y',),
              VALE='FdispX(INST,X,Y)', FdispX=FdispX);
trans1=AFFE_CHAR_MECA_F(MODELE=model,
                        DDL_IMPO=_F(GROUP_NO='mondaiNai',
                                    DX=deplX,),);
#4 2021-01-30 16:34:23
fraperrone18
Thanks for the tips.
Could you please explain to me what you did?
