#1 2021-04-14 21:42:14
kmmarquezf
Get the new coordinates of a deformed mesh
I have managed to modify a mesh in order to obtain a deformed one. However, when I try to get the new node coordinates through MAYL_PY, I get an error. How can I fix this error?
This is the part of the code where I modify the mesh:
    DISPL=CREA_CHAMP(TYPE_CHAM='NOEU_DEPL_R',
                                            OPERATION='EXTR',
                                            RESULTAT=res,
                                            NOM_CHAM='DEPL',)
    MAIL_MEC=MODI_MAILLAGE(reuse =MAIL_MEC,
                                                         MAILLAGE=MAIL_MEC,
                                                         DEFORME=_F(OPTION='TRAN',
                                                         DEPL=DISPL,))
    ALLdat2 = MAIL_PY()
    ALLdat2.FromAster(MAIL_MEC)
    ALLCrd = ALLdat2.cn
And this is the error that I get:
   ! erreur non prevue et non traitee prevenir la maintenance                    !
   ! Traceback (most recent call last):                                          !
   !    File "/home/kale/salome_meca/V2019.0.3_universal/tools/                  !
   ! Code_aster_stable-v144_smeca/lib/aster/Noyau/N_JDC.py", line 225, in        !
   ! exec_compile        !
   !     exec(self.proc_compile, self.g_context)                                 !
   !    File "fort.1", line 740, in <module>                                     !
   !     ALLdat2.FromAster(MAIL_MEC)                                             !
   ! Code_aster_stable-v144_smeca/lib/aster/Utilitai/partition.py", line 238, in !
   ! FromAster        !
   !     nom_maillage = nom.nom                                                  !
   !  AttributeError: 'tuple' object has no attribute 'nom'                      !
#2 2021-04-15 12:49:21
kmmarquezf
Re: Get the new coordinates of a deformed mesh
UPDATE:
I managed to get the coordinates of the deformed mesh, but I think it should be an easier way (plus I'll end with like large number of mesh files).
This is what i did: I just printed the mesh and read it again O.o, but I don't think that this is a practical way and for some reason I get orphan nodes warnings.
BTW I need the coordinates because according to the new position of the nodes i'll have to apply a new displacement to some of them and update the mesh again and do the analysis to this new mesh until a stop criteria is reached. Similar as simulating growth of a tissue.
What I did was the following:
for i range  (1,grwstp)
    #creation of the displacement field
                                            OPERATION='EXTR',
                                            RESULTAT=res,
                                            NOM_CHAM='DEPL',)
    #modification of the mesh based on the displacement field
        MAILLAGE=MAIL_MEC,
        DEPL=DISPL,))
    #Deformed mesh in MED FILE printing
    outFileName=path_def_mesh+"/def_mesh"+str(i)+".med"
    outFile=open(outFileName, "w")
    DEFI_FICHIER(ACTION='ASSOCIER',
                                              FICHIER=path_def_mesh+'/def_mesh'+str(i)+'.med',
                                              UNITE=i+100)
    IMPR_RESU(FORMAT='MED',
                          UNITE=i+100,
                          RESU=_F(MAILLAGE=MAIL_MEC))
    #Reading the deformed mesh
    DEFI_FICHIER(ACTION='LIBERER',
                              UNITE=i+100)
                              UNITE=i+200)
    MAILMEC2 = LIRE_MAILLAGE(FORMAT='MED',
                                                         UNITE=i+200)
    #Manipulation of the mesh with python
    ALLdat2 = MAIL_PY() # Function to access mesh with python
    ALLdat2.FromAster(MAILMEC2)
    ALLCrd2 = ALLdat2.cn
    print('ESTE ES EL MAXIMOOO F',i,i,i, np.max(ALLCrd2[:,1], axis=0), ALLCrd2[1106,0]) #Eval of one node to check if dx is changing
I was just wondering why is it not possible to use MAIL_PY for a  mesh two times in the same analysis?? even more if the mesh have been modified with the MODI_MAILLAGE opeator. (at the beginning of my analysis I used  MAIL_PY to get some information of the pre-deformed mesh)
Anyway, I'm open to suggestions to improve this part of my code, because I truly don't thing this is an optimal way and I'm not very sure of why I got the error.
Thank you very much for taking the time to read this and have a good day!
#3 2021-04-23 05:49:06
your first solution should work, cf. attached file. Is it possible to share your comm file and mesh?
#4 2021-05-08 23:40:35
MrSnail
kmmarquezf - not sure if that would help you but if you save out the deformed mesh in Aster format instead of med, you have all the node coordinates in a .mail file which is already a text.
Otherwise just for info, you can even scale a deformed mesh like that... maybe there is an in-built function for you too?
scale = 238
shape = CREA_CHAMP(identifier='1:3',
                   NOM_CHAM='DEPL',
                   NUME_ORDRE=1,
                   OPERATION='EXTR',
                   RESULTAT=modes,
                   TYPE_CHAM='NOEU_DEPL_R')
defmesh = CREA_CHAMP(identifier='2:3',
                     COMB=_F(CHAM_GD=shape,
                             COEF_R=scale),
                     OPERATION='COMB',
mesh = MODI_MAILLAGE(identifier='3:3',
                     reuse=mesh,
                     DEFORME=_F(DEPL=defmesh,
                                OPTION='TRAN'),
                     MAILLAGE=mesh)
IMPR_RESU(identifier='4:3',
          RESU=_F(MAILLAGE=mesh),
          UNITE=13)
#5 2021-05-11 07:38:01
kmmarquezf
Konyaro, I know it should work, but for me it was not maybe I had (or have) and error somewhere. I attached the meshes and comm files.
There are some path in the file that should be changed (it is a huge code).
MrSnail, I'll check if there is a function for the growth.
Thank you both for he information.
