#1 2021-10-06 14:51:29
massimobrivio
salome meca 2021 installation problems
I'm installing Salome Meca 2021on Ubuntu 18.04 using WSL2. I installed Singularity successfully as described in the installing guidelines.
When trying to launch the application with:
./salome_meca-lgpl-2021.0.0-1-20210811-scibian-9 --soft
I get the following error:
not exist: /etc/krb5.conf
not exist: ${XDG_RUNTIME_DIR}
INFO : Running salome_meca in software rendering mode
runSalome running on R01
ERROR:salomeContext:Unexpected error:
  File "/opt/salome_meca/Salome-V2021-s9/modules/KERNEL_V9_7_0/bin/salome/salomeContext.py", line 278, in _startSalome
    res = getattr(self, command)(options) # run appropriate method
  File "/opt/salome_meca/Salome-V2021-s9/modules/KERNEL_V9_7_0/bin/salome/salomeContext.py", line 357, in _runAppli
    runSalome.runSalome()
  File "/opt/salome_meca/appli_V2021/bin/salome/runSalome.py", line 925, in runSalome
    clt,args = main()
  File "/opt/salome_meca/appli_V2021/bin/salome/runSalome.py", line 851, in main
    searchFreePort(args, save_config, args.get('useport'))
  File "/opt/salome_meca/appli_V2021/bin/salome/searchFreePort.py", line 116, in searchFreePort
    queue = Queue()
  File "/opt/python/3.6.5/lib/python3.6/multiprocessing/context.py", line 102, in Queue
    return Queue(maxsize, ctx=self.get_context())
  File "/opt/python/3.6.5/lib/python3.6/multiprocessing/queues.py", line 42, in __init__
    self._rlock = ctx.Lock()
  File "/opt/python/3.6.5/lib/python3.6/multiprocessing/context.py", line 67, in Lock
    return Lock(ctx=self.get_context())
  File "/opt/python/3.6.5/lib/python3.6/multiprocessing/synchronize.py", line 163, in __init__
    SemLock.__init__(self, SEMAPHORE, 1, 1, ctx=ctx)
  File "/opt/python/3.6.5/lib/python3.6/multiprocessing/synchronize.py", line 60, in __init__
    unlink_now)
FileNotFoundError: [Errno 2] No such file or directory
singularity exit code: 1
Any idea on which could be the error?
#2 2021-10-07 17:50:55
ing.nicola
Re: salome meca 2021 installation problems
for me error is due to base OS,try ubuntu 20.04, there should be for WSL ....
for install singualrity i used this procedure ( on linux native xubuntu 20.04 )
sudo apt-get update && \
sudo apt-get install -y build-essential \
libseccomp-dev pkg-config squashfs-tools cryptsetup
sudo rm -r /usr/local/go
export VERSION=1.13.15 OS=linux ARCH=amd64  # change this as you need
wget -O /tmp/go${VERSION}.${OS}-${ARCH}.tar.gz https://dl.google.com/go/go${VERSION}.${OS}-${ARCH}.tar.gz && \
sudo tar -C /usr/local -xzf /tmp/go${VERSION}.${OS}-${ARCH}.tar.gz
echo 'export GOPATH=${HOME}/go' >> ~/.bashrc && \
echo 'export PATH=/usr/local/go/bin:${PATH}:${GOPATH}/bin' >> ~/.bashrc && \
source ~/.bashrc
curl -sfL https://install.goreleaser.com/github.com/golangci/golangci-lint.sh |
sh -s -- -b $(go env GOPATH)/bin v1.21.0
mkdir -p ${GOPATH}/src/github.com/sylabs && \
cd ${GOPATH}/src/github.com/sylabs && \
git clone https://github.com/sylabs/singularity.git && \
cd singularity
git checkout v3.6.3
cd ${GOPATH}/src/github.com/sylabs/singularity && \
./mconfig && \
cd ./builddir && \
make && \
sudo make install
singularity version
#3 2021-10-08 07:57:15
massimobrivio
I tried your installation for singularity and then I tried to install on WSL2 running Ubuntu 20.04 and I got exactly the same error.
#4 2021-10-10 16:26:55
filjan
Hi massimobrivio,
I have same problem in WSL2 on Ubuntu 20.04, on Win10
runSalome running on DESKTOP-3H9G6D5
    clt,args = main()
    queue = Queue()
    unlink_now)
If you solve the problem, don't miss to share solution please.
regards
Filjan
#5 2021-10-10 17:44:47
massimobrivio
Hi Filjan,
Unfortunately didn’t manage to get around it so far.
Of course I’ll let you know in case I manage.
Massimo
#6 2021-10-14 14:25:42
carv
Same error!
filjan wrote:
Hi massimobrivio,
    clt,args = main()
    queue = Queue()
    unlink_now)
regards
Filjan
#7 2021-10-20 11:39:58
urs helfenstein
I guess I ran into the same issue. The only difference I see at the end: "OSError: Error 30] Read-only file system"
Was there any possibility to let it run?
/home# ./salome_meca-lgpl-2021.0.0-0-20210601-scibian-9
INFO:    Could not find any nv files on this host!
runSalome running on CHNL089
    clt,args = main()
    queue = Queue()
    unlink_now)
OSError: [Errno 30] Read-only file system
#8 2021-10-20 12:09:36
rmoio
I get the same identical error on WSL2 with both Ubuntu 18.04 and 20.04 and with Debian too.
#9 2021-10-22 15:27:05
massimobrivio
    clt,args = main()
    queue = Queue()
    unlink_now)
Hello Urs, you will have the same error as me if you would run with --soft option.
Still didn't manage to get the answer, unfortunately
Massimo
#10 2021-10-25 09:13:00
urs helfenstein
Hello Massimo
Correct, if I start with the --soft option I get aswell the same exit error as you
    clt,args = main()
    queue = Queue()
    unlink_now)
Massimo
#11 2021-11-05 10:43:35
MiSch
Dear All I am running in totaly different trouble when I use :
/singularity run --app install salome_meca-lgpl-2021.0.0-0-20210601-scibian-9.sif
I got following error:
FATAL:   container creation failed: mount /proc/self/fd/3->/usr/local/var/singularity/mnt/session/rootfs error: while mounting image /proc/self/fd/3: kernel reported a bad superblock for squashfs image partition, possible causes are that your kernel doesn't support the compression algorithm or the image is corrupted
I am using Ubuntu 20.04 in a VMbox
Can someone help mie with this issue?
Best wishes
Michael
#12 2021-11-05 10:51:37
you could try a newer version of singularity. A similar error has been reported with Ubuntu 18.04:
https:__//github.com/hpcng/singularity/issues/5466 (remove the __ no links allowed),
#13 2021-11-07 17:12:03
EnKiNekiDela
Any news on this issue?
I tried with singularity SingularityCE 3.9.0 RC1 and Singularity 3.7.4 on wsl2 18.04. Same error as described already. Seems to stall on GUI as other continers work normally.
Thanks and regards.
mf wrote:
#14 2021-11-09 09:25:57
stefano89
I follow this post, because I also have the same error.
All the best
Stefano
#15 2021-11-09 21:06:18
hberro
At one point during our tests on WSL2, we found it necessary to do the following
sudo rm -r /dev/shm
sudo mkdir /dev/shm
sudo chmod 777 /dev/shm
Hope it helps, let us know please.
HB
#16 2021-11-10 09:25:57
rmoio
sudo rm -r /dev/shm
sudo mkdir /dev/shm
HB
After running these commands salome-meca now works correctly. Thank you very much.
#17 2021-11-10 19:21:52
EnKiNekiDela
tested with proposal and now I got following errors...
lga@DESKTOP-R5TDPJ2:~/salome_meca$ ./salome_meca-lgpl-2021.0.0-1-20210811-scibian-9
runSalome running on DESKTOP-R5TDPJ2
Searching for a free port for naming service: 2812 - OK
Searching Naming Service  + found in 0.1 seconds
Searching /Kernel/Session in Naming Service  +++++Traceback (most recent call last):
  File "/opt/salome_meca/Salome-V2021-s9/modules/KERNEL_V9_7_0/bin/salome/orbmodule.py", line 181, in waitNSPID
    os.kill(thePID,0)
ProcessLookupError: [Errno 3] No such process
During handling of the above exception, another exception occurred:
  File "/opt/salome_meca/appli_V2021/bin/salome/runSalome.py", line 694, in useSalome
  File "/opt/salome_meca/appli_V2021/bin/salome/runSalome.py", line 639, in startSalome
  File "/opt/salome_meca/Salome-V2021-s9/modules/KERNEL_V9_7_0/bin/salome/orbmodule.py", line 183, in waitNSPID
RuntimeError: Process 4486 for /Kernel/Session not found
...would apprecite any further suggestions, thanks in advance.
Edit: tried with python 2.7 and 3.6. Added "export LD_LIBRARY_PATH=/usr/local/Qt-5.15.3/lib:$LD_LIBRARY_PATH".
sudo rm -r /dev/shm
sudo mkdir /dev/shm
HB
#18 2021-11-13 18:56:43
hberro
To be honest the output error is too generic to give you advice, did you follow the steps specific for WSL2 ?
#19 2021-11-14 07:41:58
johan
Contrary to some of the posts above, and following the instructions to the letter, I installed SM2021 on Ubuntu 20.04 without any hiccups. My compliments to the developers. This was a pleasure. Keep up the good work.
Loading an existing simulation into 2021, I encountered 2 problems.
1. I can only access the installation disk. /mnt and /media are both empty. This is not insurmountable but inconvenient.
2. In the simple viewer in Code-Aster I can pan and zoom, but I can not rotate the image. For me this is serious because this is my preferred viewer.
Any help with the above will be appreciated
#20 2021-11-14 10:49:06
EnKiNekiDela
Thank you so much for your guidance it helped a lot.
I am not sure why, but it did help creating launcher on desktop (I use xfce) pointing to salome_meca executable file, as running it from terminal results in my above mentioned general error.
For all finding typing sudo commands before start tedious this might help:
1. creating excutable e.g. salome.sh with:
#!/bin/sh -e
set -e
rm -r /dev/shm
mkdir /dev/shm
chmod -R a+rwx /dev/shm
exit 0
2. setting up crontab: https:_____//phoenixnap.com/kb/crontab-reboot" , putting in crontab file e.g.:
@reboot sleep 10 && /here_put_your_path_to_executable/salome.sh
3. making crontab service start on wsl2 startup, since it is stopped by default at each startup: https:____//askubuntu.com/questions/1165969/ubuntu-18-04-on-wsl-cron-daemon-not-running-after-reboot
There might be other ways to approach this, running salome.sh as service, but in my case those didn't work.
#21 2021-11-15 16:10:30
k_zurawski
Hi. I was able to reproduce the same error:
krzysztof@Stacja:~$ ./salome_meca-lgpl-2021.0.0-0-20210601-scibian-9
runSalome running on Stacja
Searching for a free port for naming service: 2811 - OK
Searching /Kernel/Session in Naming Service  ++++++++++Traceback (most recent call last):
    os.kill(thePID,0)
RuntimeError: Process 4802 for /Kernel/Session not found
Well, since I'm no IT specialist I'd be glad if someone could help me and others running this great piece of software.
regards,
Krzysztof
#22 2021-11-15 18:05:31
k_zurawski
OK. I tried to install Salome-Meca2021:
- on separate drive with Ubuntu 20.04 LTS with no success
- on Windows 10 Pro with Ubuntu 20.04 LTS with WSL2 - no success
- on Virtual Box machine with Ubuntu 20.04 LTS - no success
- on Hyper-V with Ubuntu 20.04 LTS also with no success (also graphics work slowly on that last one)
I also tried to install Salome-Meca2018 & 2019 on separate drive with Ubuntu 20.04 LTS - still no success
Then I tried to install Windows port of Salome Meca 2019 where I shuld install Microsoft C++ redist version 2014 which you can't find on the Internet (2013 and 2015 are easy to find)...
As you can see I really want to run it. The most desirable solution would be running under Windows via WSL2, but that seems to be out of my reach. HELP, HILFE, Au secours!
regards,
Krzysztof
#23 2021-11-16 20:31:21
filjan
Hi!
for me help EnKiNekiDela hint about bulding executable in the desktop and running through xfce4 window (Thanks!). Trying to run salome_meca through wsl terminal indirectly ends with failure though. Working through xfce has unfortunately some inconvienient lags : /
@ k_zurawski - I assume you are Polish too - don't hesitate to write me message in any question, I'll be glad to help.
Filjan
Edit:
PS: I forgot to mention that this time I've used Ubuntu 18.04.
